[Geoserver-devel] debug gs in eclipse with tomcat 6.0
Hi:
I want to debug the gs in the eclipse since I add some breakpoints in the codes.
I found that I can change the web-app module to a dynamic web project by modify the project facets of this module, then I can use the command " debug on server " to run the gs in the web container, however it fails.
Then I go to the geoserver document for answer and I found the something here:
http://docs.geoserver.org/2.0.0/developer/maven-guide/index.html#running-the-web-module-with-jetty
It tell me about run gs with jetty, and it notes that :
**cd geoserver_1.7.x/src/web**
**mvn jetty:run**
Note
This command must be run from the web module, it will fail if run from elsewhere.
So I wonder if I shoud run the gs in under the web directory, however I found that I can not change the web module to a dynamic web project, why?
Then how to debug the gs with tomcat in the IDE (eclipse)?
2009/12/15 maven apache <apachemaven0@anonymised.com>
Hi:
**mvn jetty:run**
Note
The project and the error message:http://imagebin.org/75561
Are you following the steps in the developers’ guide? http://docs.geoserver.org/2.0.x/en/developer/quickstart/index.html#generate-eclipse-project-files-with-maven shows exactly how to do this. Note that it is a bit more complicated than just having eclipse search for source files in the SVN checkout directory.
2009/12/15 David Winslow <dwinslow@anonymised.com>
On 12/15/2009 08:30 AM, maven apache wrote:
2009/12/15 maven apache <apachemaven0@anonymised.com.403…>
Hi:
<b>cd geoserver_1.7.x/src/web
mvn jetty:run</b>
Note
Return on Information:
Google Enterprise Search pays you back
Get the facts.
[http://p.sf.net/sfu/google-dev2dev](http://p.sf.net/sfu/google-dev2dev)
Geoserver-devel mailing list
[Geoserver-devel@lists.sourceforge.net](mailto:Geoserver-devel@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-devel](https://lists.sourceforge.net/lists/listinfo/geoserver-devel)
Yes, I followed it .I have imported the sources to eclipse successfully.
David Winslow
OpenGeo - http://opengeo.org/
Then are the steps under ‘Run GeoServer Under Eclipse’ not working for you? Perhaps I am misreading your email.
