Can anyone out there give me a "detailed decription"
of how you are running the geoserver in debug mode
using eclipse. I am guessing you are using the jetty
servlet engine which comes with the geoserver sources.
If anyone is doing it with a tomcat plugin, maybe
that could be described as well. I would be very
interested.
I would find it very valueable if you could create a
section in the wiki where this is explained in detail.
arccrap
_______________________________
Do you Yahoo!?
Declare Yourself - Register online to vote today! http://vote.yahoo.com
Look into running the build script target through the debugger.
BTW, what's your real name / organization ? (kinda neat to know who's
using the code you wrote ... )
David
On Thu, 2004-10-07 at 13:32, arc crap wrote:
interested.
arccrap
Do you Yahoo!?
This SF.net email is sponsored by: IT Product Guide on ITManagersJournal
Use IT products in your business? Tell us what you think of them. Give us
Your Opinions, Get Free ThinkGeek Gift Certificates! Click to find out more http://productguide.itmanagersjournal.com/guidepromo.tmpl
Geoserver-devel mailing list
Geoserver-devel@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geoserver-devel
I was hoping for a little more detailed answer.
Which target do you run in the debugger, and does it
also allow you to debug the struts jsps?
ArcCrap
the debugger.
neat to know who's
David
> Hi,
decription"
jetty
sources.
maybe
> interested.
create a
detail.
> Thanks,
> arccrap
> Do you Yahoo!?
We have been out of the loop for a while - I am afraid STRUTS debugging was reserved for the pay as you play WebSphere products when we last worked on this.
In general you can run the Tomcat application in the debugger right now.
Jetty is included with GeoServer and may be easier to run directly - we will have to ask Chris Holme, or look at the ant "test" target.
