[Geoserver-devel] Decorating animations
we’d like to extend the animator to have the indication of the param values associated with that
frame as a label in a corner of the animation.
I was thinking about it and it seems to me the easiest, most natural way could be to leverage
map decorations, adding a new type of templatable decoration that uses the “env” filter
function as the source of values to be expanded.
This new “MessageDecoration” would be configurable using font family, size, bold/italic,
halo radius and halo color, and the message could be either fixed, or a CQL expression
just like in the “dynamic symbolizers”, that is something like:
This is year ${env(“time”)}
where whatever is in ${…} is interpreted as a CQL expression.
Another option could be that the message is interpreted as a Freemarker template that is
then fed the env variables as the evaluation context.
Hum… I guess I like the second better, what do you say?
The animator would then stick into the env function the current param value.
Text wise, nothing fancy, I don’t think I’m going to add wrapping and the like for example.
Opinions?
Ing. Andrea Aime
Tech lead
Via Poggio alle Viti 1187
fax: +39 0584 962313
http://www.youtube.com/user/GeoSolutionsIT
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
Not by domain but it sounds pretty reasonable to me. Not sure which option I like better… I think the first maybe… seems more direct. If the second is used how will the template lookup occur? Same directory that the current template file is located in? Regardless though +1 on the idea.
On Mon, Oct 24, 2011 at 7:42 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Opinions?
Ing. Andrea Aime
Tech lead
The demand for IT networking professionals continues to grow, and the
demand for specialized networking skills is growing even more rapidly.
Take a complimentary Learning@anonymised.com Self-Assessment and learn
about Cisco certifications, training, and career opportunities.
http://p.sf.net/sfu/cisco-dev2dev
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
On Wed, Oct 26, 2011 at 7:50 AM, Justin Deoliveira <jdeolive@anonymised.com.1501…> wrote:
Ah, I was thinking of putting the template right inside the decorator configuraton, as a cdata section (it’s going to be very small anyways)
Ing. Andrea Aime
Tech lead
