Andrea,
I am the component lead of GS Application schema, but I am not the default assignee of new issues. Should I be? Can this be changed?
Kind regards,
Ben.
-------- Original Message --------
Subject: [Geoserver-devel] [jira] Created: (GEOS-3805) java.lang.IllegalStateException: Subject type not loaded yet
Date: Thu, 11 Feb 2010 14:26:55 +0800
To: geoserver-devel@lists.sourceforge.net <geoserver-devel@lists.sourceforge.net>
Key: GEOS-3805
URL: http://jira.codehaus.org/browse/GEOS-3805
Project: GeoServer
Issue Type: Bug
Components: Application schema
Affects Versions: 2.0.x
Reporter: Florence Tan
Assignee: Andrea Aime
As GeoServer only allows one FeatureType of same type per instance, in order to achieve more than one silimar type, a new schema been created to have the similar type with different element name:
1) Created a new schema under a new profiles directory
(profiles/Borehole.xsd)
<schema xmlns="http://www.w3.org/2001/XMLSchema" xmlns:gml="http://www.opengis.net/gml" xmlns:gsml="urn:cgi:xmlns:CGI:GeoSciML:2.0" xmlns:sa="http://www.opengis.net/sampling/1.0" xmlns:om="http://www.opengis.net/om/1.0" xmlns:xlink="http://www.w3.org/1999/xlink" targetNamespace="urn:cgi:xmlns:CGI:GeoSciML:2.0">
<annotation>
<documentation>Profile wrapper for Borehole</documentation>
</annotation>
<import namespace="http://www.opengis.net/gml" schemaLocation="http://schemas.opengis.net/gml/3.1.1/base/gml.xsd"/>
<import namespace="http://www.opengis.net/sampling/1.0" schemaLocation="http://schemas.opengis.net/sampling/1.0.0/sampling.xsd"/>
<include schemaLocation="http://www.geosciml.org/geosciml/2.0/xsd/geosciml.xsd"/>
<element name="BoreholeHeader" type="gsml:BoreholeType" substitutionGroup="sa:SamplingCurve"/>
</schema>
2) Have the geoserver config file pointing to the new schema file :
<targetTypes>
<FeatureType>
<schemaUri>../profiles/Borehole.xsd</schemaUri>
</FeatureType>
</targetTypes>
3) Running the config file will receive the following java exception :
<ows:ExceptionReport version="1.0.0" xsi:schemaLocation="http://www.opengis.net/ows http://localhost:8080/geoserver/schemas/ows/1.0.0/owsExceptionReport.xsd" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:ows="http://www.opengis.net/ows">
- <ows:Exception exceptionCode="NoApplicableCode">
<ows:ExceptionText>java.lang.IllegalStateException: Subject type not loaded yet Subject type not loaded yet</ows:ExceptionText>
</ows:Exception>
</ows:ExceptionReport>
SOLARIS 10 is the OS for Data Centers - provides features such as DTrace,
Predictive Self Healing and Award Winning ZFS. Get Solaris 10 NOW
http://p.sf.net/sfu/solaris-dev2dev
Geoserver-devel mailing list
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer, CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
26 Dick Perry Ave, Kensington WA 6151, Australia
