I am a loss to explain why but when i ran the cite tests on built artifacts for 2.1-beta1 I ran into some issues with some tests failing. And I have been running the same tests all week and the same tests did not fail. The issue occurs due to the output strategy of speed being used, and the test case test an exception case.
By definition with speed this is not meant to work as with that output strategy output gets written immediately, so when the exception report is written the result is an invalid document.
Looking at svn history it seems SPEED has been the default for quite some time. I am puzzled, I am not sure how tests have been passing recently… and what made it all of a sudden start failing. And I don’t see any recent changes that could have caused this change.
Any thoughts?
-Justin
Justin Deoliveira
OpenGeo - http://opengeo.org
Justin Deoliveira ha scritto:
Looking at svn history it seems SPEED has been the default for quite some time. I am puzzled, I am not sure how tests have been passing recently... and what made it all of a sudden start failing. And I don't see any recent changes that could have caused this change.
Any thoughts?
I have no idea of what could have caused that. However we can just
go back to the partial buffer strategy, should be good out of the box
Andrea Aime
Ok, I will drop us back to partial buffer.
Any thoughts?
Andrea Aime
Justin Deoliveira
