Hello,
a patch for item (1) of http://jira.codehaus.org/browse/GEOS-3621 is available. I'll also provide a patch for item (2) - when I find the time
In the meantime, if someone could point me to the wicket stuff relevant to deleting a style (class and html snippet), I'll (try to) take care of implementing the behaviour in the UI. (Something like a simple "purge style file" check box.)
Ugo
Hi Ugo,
I just applied the patch you submitted (with some tests and a few modifications). Great work! Thanks for that.
You can look at the StyleEditPage in the web-wms module for a place to start on adding purge functionality to the UI.
Ugo Taddei wrote:
Hello,
Ugo
Throughout its 18-year history, RSA Conference consistently attracts the
world's best and brightest in the field, creating opportunities for Conference
attendees to learn about information security's most important issues through
interactions with peers, luminaries and emerging and established companies.
http://p.sf.net/sfu/rsaconf-dev2dev
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
