[Geoserver-devel] Dem and Sattalitte Image support in Geoserver
  Does geoserver support dem and sattalitte image(tiff)? Do I have to use
WCS to support this? Does WMS support this?
  Thank u very much.
  Rong
I'm pretty sure it does. You'll need the WCS branch, but your data will
be available through WMS as well (just like the vector side, configure
once, and it's available in WMS as well as W(F|C)S). The WCS stuff is 0.2
alpha, so still working bugs out, performance isn't what it could be, and
a user was having trouble getting geotiff to work, and there aren't many
docs yet. But it should be possible, and hopefully Alessio and Simone
will answer soon.
Chris
  Thank u very much.
  Rong
SF.Net email is sponsored by: Discover Easy Linux Migration Strategies
from IBM. Find simple to follow Roadmaps, straightforward articles,
informative Webcasts and more! Get everything you need to get up to
speed, fast. http://ads.osdn.com/?ad_idt77&alloc_id492&op=click
Geoserver-devel mailing list
sorry for answering with such a delay but I got back on monday from Norway where I spent one month in live demo where we used GeoServer pretty successfully. Alessio is on vacation this week and apparently he forgot that he is supposed to be the referrer for the WCS and therefore he was supposed to send out an email to warn everybody out of his absence. Anyway, I will be around and if anybody has questions or whatever I will be glad to answer.
Back to the topic.
WCS support geotiff even though as I said in a previous email we are focusing now in supporting BIG geotiff since at the beginning there was no time for fancy code on this issue. Just use the format for taggef imade with georefencing. If you ran into problem let me know. If you have suggestions ar complains let me know as well.
WCS support reading and writing gtopo30 quads. A gtopo30 quad is a set of 8 files from USGS which contains between the others a DEM file (16 bits integers elevation values). If you meant that as DEM (that is a gtopo30 file) we support it, if you meant a simple .DEM as it is, file we don’t at the moment but if we get enough requests for that we will provide support for it since it should be not very difficult to achieve.
I hope I cleared out some of your doubts, anyway write again whenever you feel like and I will try to help you out.
Simone.
On 6/28/05, Chris Holmes <cholmes@anonymised.com.13…> wrote:
I’m pretty sure it does. You’ll need the WCS branch, but your data will
once, and it’s available in WMS as well as W(F|C)S). The WCS stuff is 0.2
alpha, so still working bugs out, performance isn’t what it could be, and
a user was having trouble getting geotiff to work, and there aren’t many
will answer soon.
Chris
Thank u very much.
Rong
speed, fast. [http://ads.osdn.com/?ad_idt77&alloc_id492&op=click](http://ads.osdn.com/?ad_idt77&alloc_id492&op=click)
speed, fast. http://ads.osdn.com/?ad_id=7477&alloc_id=16492&op=click
Thanks a lot for your detail explaination.
that
supposed
be
Back to the topic.
with
8
file) we support it, if you meant a simple .DEM as it is, file we don't at
Simone.
On 6/28/05, Chris Holmes <cholmes@anonymised.com> wrote:
> Hi,
use
0.2
and
will answer soon.
Chris
> Thank u very much.
> Rong
> SF.Net <http://SF.Net> email is sponsored by: Discover Easy Linux
> https://lists.sourceforge.net/lists/listinfo/geoserver-devel
