[Geoserver-devel] Dependencies for 2.4.8 in repositories missing
Hello,
I’ve checked at http://repo.boundlessgeo.com/main/ and https://boundless.artifactoryonline.com/boundless/main/ and neither repository holds the full set of artifacts for (at least) version 2.4.8 of Geoserver, including the extensions (specifically, WPS). We are currently unable to build from scratch due to this. Does anyone have an alternate Maven repository they are using for building or can someone (Andrea?) deploy the 2.4.8 version of Geoserver and extensions up?
Hi Ivan,
the GeoServer 2.4.x series been unsupported for a long time now.
Recently we have had issues with the repositories and switched to a new infrastructure, not sure if we can salvage
those jars from the old repo at all? Jody?
PS: a manual deploy would take a few hours for me due to the ADSL line I have available (uploads are rather slow),
does not look like the best use of my weekend free hours :wink:
On Tue, Nov 10, 2015 at 7:28 PM, Ivan Suftin <isuftin@anonymised.com> wrote:
Hello,
Geoserver-devel mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Two things:
  1. The “original” repo.boundlessgeo.com was mirrored and syncrhonized (all previous content should be available)
  2. The repo.opengeo.org repository is still available on disk if you are completely stuck (this is the one 2.4 would of been released from).
Finally stuff is published to the OSGeo repository, do you have the OSGeo repository in your pom?
On 10 November 2015 at 18:49, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hi Ivan,
Jody Garnett
Hello,
Ing. Andrea Aime
@geowolf
Technical Lead
Hey Jody,
Here’s an example of 2.4.8 not being available: http://repo.boundlessgeo.com/main/org/geoserver/extension/wps-core/
The pom for 2.4.8 extensions is there ( http://repo.boundlessgeo.com/main/org/geoserver/extension/2.4.8/ ) but a lot (most?) of the extensions are missing the artifacts.
This also extends beyond just the extensions ( http://repo.boundlessgeo.com/main/org/geoserver/csw/ ).
On Wed, Nov 11, 2015 at 4:25 AM, Jody Garnett <jody.garnett@anonymised.com…> wrote:
Two things:
Jody Garnett
Hi Ivan,
Hello,
Ing. Andrea Aime
@geowolf
Technical Lead
__________________________ (╯°□°)╯︵ ┻━┻
Ivan Suftin - Applications Developer - isuftin@anonymised.com
Office: (608) 821-3825 - Cell : (608) 345-8963
Center for Integrated Data Analytics - http://cida.usgs.gov/
United States Geological Survey
8505 Research Way, Middleton, WI 53562
On Wed, Nov 11, 2015 at 11:25 AM, Jody Garnett <jody.garnett@anonymised.com>
wrote:
Two things:
1) The "original" repo.boundlessgeo.com was mirrored and syncrhonized
2) The repo.opengeo.org repository is still available on disk if you are
Hi Jody,
we haven't published the GeoServer jars in a long time on the OSGeo repo,
there is a couple of releases that
probably got there by accident or contingent need but it was several years
ago:
http://download.osgeo.org/webdav/geotools/org/geoserver/
Cheres
Ing. Andrea Aime
@geowolf
Technical Lead
Got an answer, here is what the old repo has:
1.7.5 2.0.3 2.1.3 2.2.1 2.2.5 2.2-RC2 2.3.1 2.3.5
2.4.0 2.4.4 2.4-beta 2.5 2.5-RC1 2.6-SNAPSHOT
1.7.6 2.1.0 2.1.4 2.2.2 2.2-beta1 2.2-RC3 2.3.2 2.3-beta1
2.4.1 2.4.5 2.4-RC1 2.5.1 2.5-RC2
2.0.1 2.1.1 2.1-SNAPSHOT 2.2.3 2.2-beta2 2.2-SNAPSHOT 2.3.3 2.3-RC1
2.4.2 2.4.6 2.4-RC2 2.5.2 2.5-SNAPSHOT
2.0.2 2.1.2 2.2 2.2.4 2.2-RC1 2.3.0 2.3.4 2.3-SNAPSHOT
2.4.3 2.4.7 2.4-SNAPSHOT 2.5-beta 2.6-beta
(Note 2.4.8 is not listed)
Hi Ivan,
Jody Garnett
Hello,
Ing. Andrea Aime
@geowolf
Technical Lead
So what should we do? Download from source forge and redeploy? Guess we would need to download the source code too and deploy the pom.xml files …
On 12 November 2015 at 19:38, Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody Garnett
Jody Garnett
Hi Ivan,
On Tue, Nov 10, 2015 at 7:28 PM, Ivan Suftin <isuftin@anonymised.com…> wrote:
Hello,
Ing. Andrea Aime
@geowolf
Technical Lead
On Fri, Nov 13, 2015 at 1:14 AM, Jody Garnett <jody.garnett@anonymised.com>
would need to download the source code too and deploy the pom.xml files ...
I believe the only solution would be to run mvn:deploy from the 2.4.8
branch?
Ing. Andrea Aime
@geowolf
Technical Lead
Created the following for you Ivan (https://osgeo-org.atlassian.net/browse/GEOS-7362).
On 12 November 2015 at 11:38, Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody Garnett
Jody Garnett
Hi Ivan,
Hello,
Ing. Andrea Aime
@geowolf
Technical Lead
