I am working on Geoserver migration from 2.8 to 2.14. This migration is
happening on JBOSS but as we don't want to disturb existing Sandbox and Dev
environment, I have created separate instance of JBOSS and deploying
Geoserver 2.14 on it. I am able to deploy it on Jboss but not sure what port
it using to launch GUI for further configuration.
Does anyone else faced similar problem in deploying Geoserver on Jboss ?
Pradeep
Sent from: http://osgeo-org.1560.x6.nabble.com/GeoServer-Dev-f3819232.html
Hi Pradeep,
Sounds like you need to lookup the default JBOSS ports in documentation, Geoserver runs inside the container and is port agnostic
regards,
Imran
I.R
Hi Imran,
I am not able to launch geoserver URL from http port defined in standalone.xml. Is there someother file which needs to be modified to launch application ?
Steps that I followed
Installed Jboss 6.4 EAP
Configured Standalone.xml
Modifed geoserver.war by adding files as per instructions
https://docs.geoserver.org/stable/en/user/tutorials/jboss/jboss_tutorial.html
4. Deployed war file in deployment directory.
Restarted jboss server and try to connect geoserver on http port defined in Jboss configuration file but nothing is happening.
While installing using windows installer it did ask for userid, password and port configuration but while installing on Jboss there is no instruction to for userid and password and even port.
Did you have well written instruction for installing it on Jboss ? Spent almost 2 days on this issue and now want to solution for it.
Pradeep
Things should be made as simple as possible and not one bit simpler
Jboss is not used by many (perhaps any) of the core developers.
This question would be more appropriate on the geoserver users' list, where
you might find someone who is familiar with it.
Brad
