I can compile and install Geoserver using Maven and the command "mvn
-o clean compile install" and I get no errors. I can run Geoserver
with the command "mvn -o jetty6:run" with no problem as well.
I want to take the generated WAR file and place it in Tomcat. When I
try to do this I get this error. I am using Tomcat 5.5.17. Does
anybody know what I can do to resolve this?
INFO: Deploying web application archive geoserver.war
04-Sep-2006 11:38:51 org.apache.catalina.startup.HostConfig deployWAR
SEVERE: Error deploying web application archive geoserver.war
java.lang.IllegalArgumentException:
log4j,openmap,postgis,jts,junitperf,junit,postgresql-E
xtension-Name
at java.util.jar.Attributes$Name.<init>(Attributes.java:440)
at java.util.jar.Attributes.getValue(Attributes.java:99)
at org.apache.catalina.util.ManifestResource.getRequiredExtensions(ManifestResourc
e.java:185)
at org.apache.catalina.util.ManifestResource.processManifest(ManifestResource.java
:154)
at org.apache.catalina.util.ManifestResource.<init>(ManifestResource.java:51)
at org.apache.catalina.util.ExtensionValidator.validateApplication(ExtensionValida
tor.java:185)
at org.apache.catalina.core.StandardContext.start(StandardContext.java:4035)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:759)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:739)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:524)
at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:809)
at org.apache.catalina.startup.HostConfig.deployWARs(HostConfig.java:698)
at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:472)
at org.apache.catalina.startup.HostConfig.start(HostConfig.java:1122)
at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:310)
at org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(LifecycleSupport.j
ava:119)
at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1021)
at org.apache.catalina.core.StandardHost.start(StandardHost.java:718)
at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1013)
at org.apache.catalina.core.StandardEngine.start(StandardEngine.java:442)
at org.apache.catalina.core.StandardService.start(StandardService.java:450)
at org.apache.catalina.core.StandardServer.start(StandardServer.java:709)
at org.apache.catalina.startup.Catalina.start(Catalina.java:551)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.ja
va:25)
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:294)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:432)
04-Sep-2006 11:38:55 org.apache.coyote.http11.Http11BaseProtocol start
xtension-Name
at
e.java:185)
at
:154)
at
at
tor.java:185)
at
at
at
at
at
at
at
at
at
at
ava:119)
at
at
at
at
at
at
at
at
va:25)
Jonathan Wong
jonnywong78@anonymised.com
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job
easier
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
Geoserver-devel mailing list
Geoserver-devel@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geoserver-devel
There is an offending jar in WEB-INF/lib.
It is wkb4j-xxx.jar (where xxx is the version number, can't remember right
now)
It is only used by postgis datastore, so if you don't need postgis access just
remove the wkb2j jar from the lib directory and you're ready to go.
We really need to fix this, I guess there was a modified version of the wkb4j
jar somewhere last year?
Gabriel
xtension-Name
at
ourc e.java:185)
at
java
:154)
at
at
lida tor.java:185)
at
at
759)
at
org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:739) at
org.apache.catalina.core.StandardHost.addChild(StandardHost.java:524) at
org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:809) at
org.apache.catalina.startup.HostConfig.deployWARs(HostConfig.java:698) at
org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:472) at
org.apache.catalina.startup.HostConfig.start(HostConfig.java:1122) at
at
rt.j ava:119)
at
org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1021) at
org.apache.catalina.core.StandardHost.start(StandardHost.java:718) at
org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1013) at
org.apache.catalina.core.StandardEngine.start(StandardEngine.java:442) at
org.apache.catalina.core.StandardService.start(StandardService.java:450) at
org.apache.catalina.core.StandardServer.start(StandardServer.java:709) at
org.apache.catalina.startup.Catalina.start(Catalina.java:551) at
sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at
9) at
l.ja va:25)
It is wkb4j-xxx.jar (where xxx is the version number, can't remember right now)
It is only used by postgis datastore, so if you don't need postgis access just remove the wkb2j jar from the lib directory and you're ready to go.
We really need to fix this, I guess there was a modified version of the wkb4j jar somewhere last year?
The geoserver 1.3.x source tree had a modified one (at least I believe it must of, since we never had this problem). If someone could put it in a repository and reference it things should work fine I believe.
Chris
Gabriel
xtension-Name
at
ourc e.java:185)
at
java
:154)
at
at
lida tor.java:185)
at
at
759)
at
at
rt.j ava:119)
at
9) at
l.ja va:25)
I dont think PostGIS datastore requires wkb4j anymore. JTS now has a
built-in WKB parser/writer. I believe there's an optimized one in the
PostGIS datastore thats about 8* as fast.
There was a discussion about it at the beginning of the year.
dave
> now)
Chris
> Gabriel
>> xtension-Name
>> at
>> ourc e.java:185)
>> at
>> java
>> :154)
>> at
>> at
>> lida tor.java:185)
>> at
>> at
>> 759)
>> at
>> at
>> rt.j ava:119)
>> at
>> 9) at
>> l.ja va:25)
Get stuff done quickly with pre-integrated technology to make your job easier
Thanks Dave, I thought I remembered something like that. So we just need to remove wkb4j from the build, and all should be good.
Chris
dave
now)
Chris
Gabriel
xtension-Name
at
ourc e.java:185)
at
java
:154)
at
at
lida tor.java:185)
at
at
759)
at
at
rt.j ava:119)
at
9) at
l.ja va:25)
Taking the library off of the build path causes compilation errors in
the attributeio classes. But it doesn't look like it would be too much
work to switch over. I can throw this on the list of things to do . If
someone has the time feel free to go ahead.
-Justin
Chris
dave
right
now)
access just
the wkb4j
Chris
Gabriel
xtension-Name
at
ourc e.java:185)
at
java
:154)
at
at
lida tor.java:185)
at
at
759)
at
at
at
at
at
at
at
rt.j ava:119)
at
at
at
at
at
at
9) at
l.ja va:25)
at
at
security?
job easier
easier
