[Geoserver-devel] Dev Docs - Programming Guide
Is it fair to say that everything under "REST Services" in the Dev Programming guide docs is out of date and no longer relevant?
https://docs.geoserver.org/latest/en/developer/programming-guide/rest-services/index.html
And does anyone else think it might be useful to search the code for all extension points and put a link on this page to the api docs for the extension point class:
https://docs.geoserver.org/latest/en/developer/programming-guide/extension-points/index.html
Ideally with some description of what the extension point is used for? And perhaps a intro explaining how to use them in general?
Chris
Chris Hodgson
Refractions Research
Suite 419 – 1207 Douglas Street
Victoria, British Columbia
Canada, V8W 2E7
1-250-383-3022
http://www.refractions.net
Is it fair to say that everything under “REST Services” in the Dev
Indeed way out of date. I actually believe most of the dev guide is out of date, believe the only current part
is the quick start information set?
It would be useful, but there are a lot of extension points and no documentation for them.
If you are willing to work on that, we can probably answer some questions here on list… time is limited
but if spread out the answers a bit we may give you enough information to get you started
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
