On Wed, 2011-01-05 at 18:54 +0100, Andrea Aime wrote:
On Wed, Jan 5, 2011 at 6:30 PM, Gabriel Roldán <groldan@anonymised.com> wrote:
> Hi all,
> as per http://jira.codehaus.org/browse/GEOS-4163, there's now the
> possibility of directly integrating GWC with the regular WMS, providing
> WMS-C capabilities directly out of the GeoServer WMS:
> * There's the possibility to enable direct GWC WMS integration
> through the UI (disabled by default)
Nice
> * The gwc module intercepts regular WMS calls, and if direct WMS
> integration is enabled, it will check whether the request comes
> with TILED=true AND matches a cached tile, and if to, will serve
> the cached copy. Otherwise it defers to the regular WMS call.
I see this has been done using Spring AOP, good.
I hope this means it's still possible to remove all GWC related jars
from GeoServer
and have it working fine.
right.
This is imperative for the WMS performance shootout, always removed GWC entirely
to prove that no caching was going on (or was possible) in the tests.
yes, it was a design decision to keep it decoupled.
Also, there is a concern that GWC embedded in GeoServer can turn into a disk
killing bomb: the tile caches can become rather large, as an administrator I'd
like to have GWC around only if I really need it, and to configure it tightly
to avoid misuse.
The default GWC configuration instead does not prevent that, which is one reason
why I normally get rid of it unless I'm actually going to use it and
configure it
in detail (btw, is the quota functionality ever going to be included
in GeoServer
GWC? That's something every conscious admin should configure, along with
the other service limits).
Agreed. The GWC integration story so far has been kind of weak IMHO. I'm
working towards improving it. Started with truncating the cache based on
transaction's affected bounds, etc. Now this direct WMS integration,
which's disabled by default. And next diskquota may arrive late this
week or the next top, with ability to set a global cache quota limit and
an expiration policy so that tiles least used get removed to keep up
with the quota.
A per-layer quota limit is also possible, but configuring that from the
GeoServer UI is part of a wider plan, so it'll take longer to arrive.
> * if the getcapabilities request comes with TILED=true, the gwc
> module contributes the WMS-C VendorSpecificCapabilities, adding
> an internal DTD definition for TileSet/Resolutions/etc and one
> TileSet per cached layer/CRS/output format combination.
> * the GetCapabilities namespace vendor specific parameter is
> respected, so that if the request comes with namespace=topp,
> only TileSets for layers in the topp namespace will be added.
Nice and nice.
> Note, however, that the default geoserver layer preview demos won't hit
> the cache because they calculate the tile origin based on the layer's
> bounding box, which generally doesn't match the GWC's gridset tile
> origin. But the WMS caps providing the WMS-C extended capabilities
> (specifically the TileSet definitions) do make it possible to create OL
> apps that match the layer's gridsets.
> It would be nice to have the layer preview match the gwc gridsets by
> default, but so far it's not such an easy task as the openlayers map
> output format is decoupled from the gwc module.
I guess it would be nice, but it would be better to do that only if GWC
is around, and without introducing a dependency. Some sort of
extension point?
right. Reason why I didn't make it so far, just ran out of time to keep
things so nice and didn't want to hack in.
Wondering if the extension point that is used to declare the tilesets
extensions in the capabilities could be also used to drive the OL
preview configuration.
Guess it has to be a separate one. That one is intended for capabilities
only and used by the inspire and gwc so far.
Thanks for the feedback Andrea.
Gabriel.
Ing. Andrea Aime
Senior Software Engineer
Via Poggio alle Viti 1187
phone: +39 0584962313
fax: +39 0584962313
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
Gabriel Roldan
Expert service straight from the developers
