Hello,
Reading the JIRA bugtracker, I was not sure if this could deserve an issue or not, so I prefer mentioning it onto the mailing list instead (at least, to start with). We had an issue with Geoserver (a custom version provided with the geOrchestra project) recently, when this one was configured to use “directories of shapefiles” datastores along with the gs-flatgeobuf extension.
On one of our setups, we were making use of “directory of shapefiles” datastores, and sometimes we weren’t able to visualize the underlying layers from this datastore but the issue was not systematic. Debugging a bit, we noticed that sometimes the datastore was created a a FlatGeobufDatastore object (when it was failing), and sometimes a ShapefileDatastore instead (when working).
Debugging a bit further, we figured out that this call in GS:
https://github.com/geoserver/geoserver/blob/main/src/main/src/main/java/org/vfny/geoserver/util/DataStoreUtils.java#L92 returns an unsorted collection, so sometimes the Shapefile factory will come first, if we were lucky, but the layer will fail if the other datastorefactory appears first.
From our point of view, the issue is that the canProcess() method on the FlatGeoBuf factory will return true in case of a directory, but won’t check if the format is actually about shapefiles (I can’t recall the params object content from my debugging session, but I am pretty sure there was something about shapefiles):
https://github.com/geotools/geotools/blob/main/modules/unsupported/flatgeobuf/src/main/java/org/geotools/data/flatgeobuf/FlatGeobufDataStoreFactory.java#L96
Hope that this could help others encountering the same issue, let us know if this deserves a bug report and/or if we can help fixing it in any ways, we decided to remove the flatgeobuf extension, as the format was actually not needed.
Best regards,
Pierre Mauduit
Ingénieur développement
Camptocamp France SAS 18 rue du Lac Saint André Savoie Technolac - Bâtiment Le Dauphin F-73370 Le Bourget du Lac Tel. +33 (0)4 58 48 20 24 Fax +33(0)4 58 48 20 10 www.camptocamp.com
Hi Pierre,
yes I believe this is worth reporting a bug.
On how to solve it, eh, there are multiple avenues:
- Make sure that GeoServer remembers the factory chosen, and gives it precedence among the stores that can handle the parameter map
- Have FlatGeoBuf implement a DBTYPE like parameter, which is used as a discriminator for factories, and it’s normally hidden from users… the ShapefileDirectoryFactory is equally at fault for just requiring a directory BTW, but it has been available for so long that changing it would affect too many existing installations.
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
Hi again,
Ok, I will do.
is it worth creating an issue on geotools as well, then ?
– Pierre
Give we have two possible fixing avenues, I would start with the GeoServer one and let whoever takes care of it to choose an appropriate path
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
