[Geoserver-devel] Disabled *cite-* jobs on ares Jenkins
I have disabled all *cite-* jobs on ares Jenkins because changes required for the migration to apollo (build.geoserver.org) cause them all to fail.
Kind regards,
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/&gt;
New Zealand
Hi Ben,
oh well, hopefully build.geoserver.org will have working jobs soon.
In the meantime I guess we’re flying blind… which will affect the maintenace
release of the 18th (2.11.3) but I guess not all that much, since it’s just getting
bug fixes.
By the way, is a volunteer needed for that release? I can help, but not the 18th,
guess I can start cutting the release around the 20th or 21th.
On Sat, Oct 14, 2017 at 12:38 AM, Ben Caradoc-Davies <ben@anonymised.com> wrote:
I have disabled all cite- jobs on ares Jenkins because changes required for the migration to apollo (build.geoserver.org) cause them all to fail.
Kind regards,
Director
Transient Software Limited <http://transient.nz/>
New Zealand
Geoserver-devel mailing list
Geoserver-devel@anonymised.comrge.net
Andrea Aime
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Hmm, were all of them failing?
The only changes that were made was an update of the cite-wfs-1.1 script, and re-adding a missing submodule to geoserver-cite-tools.
Based on this, I would only expect the various cite-wfs jobs to fail; the fact that all of them fail seems odd.
Based on the logs of these last failures, it seems like all the jobs are failing to resolve geoserver; I can’t see any error earlier in the logs as to why this might be the case.
With regards to the build.geoserver.org cite tests, we are a lot further along then we are before, but have run up against a failure coming out of the cite engine. If anyone more familiar with the cite tests could comment, that would be appreciated.
Torben
On Sat, Oct 14, 2017 at 1:07 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hi Ben,
bug fixes.
Geoserver-devel@anonymised.com.366…sourceforge.net
Kind regards,
Director
New Zealand
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
Torben,
it looks to me like the test engine is running before GeoServer is up:
https://build.geoserver.org/job/cite-wfs-1.1/1502/consoleText
I think the up-ness test is bad and tests only worked on ares because it was a slower machine and took time to build the suite. The test failure occurs before GeoServer is accepting connections. curl is probably successfully retrieving a Jetty error page.
Kind regards,
Ben.
Director
New Zealand
Andrea figured out the issue in the GeoServer meeting today - turns out that when I was getting the cite tests working on the new build server last week, the port number in /forms got changed. This is now fixed, and the ares cite tests are working again (except for wfs-1.1, which is expected). I have re-enabled all the jobs for now.
This might also be related to the failures on apollo, as I expect /forms also needs updating there. Looking into that now.
Torben
On Mon, Oct 16, 2017 at 5:37 PM, Ben Caradoc-Davies <ben@anonymised.com> wrote:
Torben,
Kind regards,
Ben.
Director
New Zealand
On Tue, Oct 17, 2017 at 7:26 PM, Torben Barsballe <
I just had a very quick look and sort of concur with Ben, except one
thing... it certainly seems like it's doing the full loop
of curl calls much faster, but I'm seeing a "sleep 2" in there that should
make it wait 2 seconds... that does not
seem to be happening though... so maybe it's not faster, GeoServer is just
not starting?
And now I've noticed this:
+ ./startup.sh -Djetty.http.port=11010
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2*./run.sh: line 78: ./startup.sh: No such file or directory*
Uh?
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
