[Geoserver-devel] Disabling a layer - expected behaviour?
Strictly speaking this isn’t necessarily a bug, but I figured I should ask about it rather than ignore it or open a JIRA straight off.
If I disable a layer by unchecking the “enabled” checkbox, The behavior then becomes rather odd:
  • GetMap requests fail (expected). But there are ERROR level events in the log which are suggesting the datastore isn’t properly configured, and one that’s an “internal error”:
2013-05-10 13:32:50,080 ERROR [geoserver.wms] - Getting feature source: featureType: Public_Data_DB:MED_AE_HOSPITALS_MIDS does not have a properly configured datastore
java.io.IOException: featureType: Public_Data_DB:MED_AE_HOSPITALS_MIDS does not have a properly configured datastore
at org.geoserver.wms.MapLayerInfo.getFeatureSource(MapLayerInfo.java:310)
at org.geoserver.wms.GetMap.executeInternal(GetMap.java:308)
2013-05-10 13:32:50,080 ERROR [geoserver.ows] -
org.geoserver.platform.ServiceException: Internal error
at org.geoserver.wms.GetMap.executeInternal(GetMap.java:330)
at org.geoserver.wms.GetMap.run(GetMap.java:201)
Caused by: java.io.IOException: featureType: Public_Data_DB:MED_AE_HOSPITALS_MIDS does not have a properly configured datastore
  • The icon next to that layer on the layer list becomes an error icon. Shouldn’t it be a red X or something to indicate it’s disabled rather than broken? I can’t find the error.png (I guess its packed somewhere) so can’t see what’s available.
  • A GetLegend request for this layer is served. Should it be if the layer is disabled? I did leave “advertised” checked, though I think that should be super-seded.
Are any of these issues I should open a JIRA for?
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
