[Geoserver-devel] DispatcherCallback.init(Request) design and... incomplete implementation
I'm looking into the dispatcher callback with a need,
I want to replace the http response with a wrapped
one that counts the bytes returned to the client.
Now, everything in the DispatcherCallback design
and implementation promises that a callback can
replace the arguments it gets with the one it will
return. For the init case:
Request init(Request);
should make it so that the Dispatcher ends up using
the Request provided by the callback, should it decide
to override it.
So far so good, but in practice it does not work for
a couple of reasons:
- the dispatcher does not really replace it Request
   with the one coming from the dispatcher callback
   chain. Ouch...
- the Request is implemented in a way that makes its
   replacement almost impossible
The first item can be fixed easily, the latter requires
a little more work. The main stoppers are that the
Request fields are using default visibility and the
Dispatcher is accessing them directly, without using
the getters.
Now, for my use case I would be content to have
the Request expose setters: in this case the
callbacks could modify the Request contents without
replacing it.
Alternatively, if we want to make the Request replaceable
with "something else" we'd have to:
- make it possible to subclass it
- make it possible to wrap it
This would amount to make all the fields protected and
make the Dispatcher access them via the getters.
At that point a dispatcher callback could roll its
own wrapper that replaces one or more of the Request
fields.
Opinions?
Andrea Aime
OpenGeo - http://opengeo.org
Makes sense. When the dispatcher was originally written the internal Request class was not intended to be made public api. But... things evolve :slight_smile:
So it sounds reasonable, make Request subclassable and wrappable. A bit of work but mostly mechanical and low risk right?
Anyways, +1 on the idea.
-Justin
On 1/26/10 10:56 AM, Andrea Aime wrote:
to override it.
    chain. Ouch...
the getters.
replacing it.
fields.
Opinions?
Justin Deoliveira
Ok. One thing. The problem could be addressed two ways:
- make all fields in the Request modifiable. Roll out setters. This
   avoids the need to change the Dispatcher and still address my
   current need. Won't make the Request any more wrappable though
- keep only getters, make fields protected, make Dispatcher access
   them via getters. This makes Request easy to wrap and subclass.
Or we could do both.
What do you think?
Andrea Aime
What do you think?
Well since we are doing the work to change it I say let's go all the way. Let's add both setters and getters for each property and make it a good old plain java bean.
Justin Deoliveira
What do you think?
Full monty patch available here: http://jira.codehaus.org/browse/GEOS-3787
Setters, getters, protected fields and javadoc, and changed the Dispatcher to actually allow callbacks to override the Request
object.
Andrea Aime
