[Geoserver-devel] displaying automated cite logs
There is now a teamengine webapp running on top of the test logs that are generated automatically. So you can use that to view the logs which is a lot nicer than the command line utility. To do so:
1. Go to http://hudson.opengeo.org:80/teamengine
2. Click "Start testing"
3. Log in with username "geoserver", and password is the same password as hudson
4. Click on the session, there will be one for each of the services we test
-Justin
Justin Deoliveira
OpenGeo - http://opengeo.org
Hem... cannot login. But I can login in hudson.
Let's discuss this privately though :slight_smile:
Well, it does not work for me but I guess past the hudles of logging in
it's going to be the best possible reporting :slight_smile:
Andrea Aime
as hudson
Just tried and could log in... you sure you tried with the username of "geoserver"?
Justin Deoliveira
