[Geoserver-devel] Doc build is failing with TimeTooSkewed error
Currently the GeoServer docs are failing to build on Jenkins due to:
upload failed: target/main/en/api/1.0.0/coveragestores.yaml to s3://[docs.geoserver.org/main/en/api/1.0.0/coveragestores.yaml](http://docs.geoserver.org/main/en/api/1.0.0/coveragestores.yaml)
An error occurred (RequestTimeTooSkewed) when calling the PutObject operation: The difference between the request time and the current time is too large.
I don’t know nearly enough about S3 to know what to do to fix this (or if we just need to change the time on build.geoserver.org??)
Ian
Ian Turton
Generally that error indicates a time issue on the source. I would check the system time on the build server, and make sure NTP daemon is working properly.
Andy
Ian
Ian Turton
Geoserver-devel mailing list
Torben did just update Jenkins / Java environment. Cannot see why that would have an effect…
Jody
Jody Garnett
‘date’ on the box showed Thu 06 Jan 2022 11:55:33 PM UTC at 2:55 pm PST (10:56 UTC), so that explains the error (although not why it is so skewed; presumably just clock drift?)
I’ve fixed the date on the server, and installed NTP so that it remains synced in the future. I’ll kick off a run of the docs and see if that fixed it.
Torben
On Thu, Jan 6, 2022 at 9:38 AM Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody
On Thu, Jan 6, 2022 at 9:30 AM Andy Curtis <andycurtis1@anonymised.com> wrote:
Andy
Ian
Ian Turton
Jody Garnett
Thanks Torben, that fixed the docs build.
Jody Garnett
