I’m not able to build the documentation of GeoServer without updating the version of Maven antrun plugin to 1.8 (note that I have the same issue with Geotools):
org.apache.maven.plugins
maven-antrun-plugin
1.8
Without this I got this exceptions:
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-antrun-plugin:1.7:run (compile) on project gs-docs: An Ant BuildException has occured: The following error occurred while executing this line:
[ERROR] jar:file:/home/nuno/.m2/repository/org/apache/maven/plugins/maven-antrun-plugin/1.7/maven-antrun-plugin-1.7.jar!/org/apache/maven/ant/tasks/antlib.xml:24: The following error occurred while executing this line:
[ERROR] jar:file:/home/nuno/.m2/repository/org/apache/ant/ant/1.8.2/ant-1.8.2.jar!/org/apache/tools/ant/antlib.xml:37: Could not create task or type of type: componentdef.
Is anyone else having this issues or I’m just very unlucky and for some reason my class-path gets broke
Note that this is not something new (I always had this issue with GT documentation) and by the way what happen to GS makefiles for building the documentation (I probably missed something) ?
It was really nice to be able to build only HTML documentation for example with the makefiles.
Nuno Oliveira
Visit [http://goo.gl/it488V](http://goo.gl/it488V) for more information.
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Software Engineer
Via di Montramito 3/A
mob: +39 333 8128928
[http://www.geo-solutions.it](http://www.geo-solutions.it)
[http://twitter.com/geosolutions_it](http://twitter.com/geosolutions_it)
Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i file/s allegato/i sono
da considerarsi strettamente riservate. Il loro utilizzo è consentito esclusivamente al destinatario del messaggio, per le finalità indicate
nel messaggio stesso. Qualora riceviate questo messaggio senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia via e
-mail e di procedere alla distruzione del messaggio stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo
anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità diverse, costituisce comportamento contrario ai
The information in this message and/or attachments, is intended solely for the attention and use of
the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree
June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying,
distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named
addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the
information in this message that has been received in error. The sender does not give any warranty or accept liability as the content,
accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which
arise as a result of e-mail transmission, viruses, etc.
