It’s very intermittent.
Compare the term “labelling” (my original search that identified this).
For 2.3.5:
http://docs.geoserver.org/2.3.5/user/search.html?q=labelling - there’s a huge wall of results.
For 2.4.0:
http://docs.geoserver.org/2.4.0/user/search.html?q=labelling
Two results, and neither is the page called “labeling”!
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
On 25 October 2013 16:31, David Winslow <dwinslow@anonymised.com> wrote:
The search returns SLD pages for me for some queries (example: http://docs.geoserver.org/2.4.0/user/search.html?q=book )
I’m not totally sure what’s up, the search actually happens in the browser based on a full index that is served as a JavaScript script. I see a JS console error on page load but like I said some terms still give results.
On Fri, Oct 25, 2013 at 11:25 AM, Jonathan Moules <jonathanmoules@anonymised.com> wrote:
Hi Andrea,
The search box definitely used to work for the pre-2.4.0 documents. Something appears to have happened to make them disappear from the results with that release though.
I can set up a custom search easily enough - (include site:http://docs.geoserver.org/stable/en/user/ and it’ll only get the GeoServer docs). But many users will use the GeoServer Search because it’s there. A false negative is worse than no search function because it implies to the user that there is no documentation on something. I’m guessing you or someone has the stats for server-search use so you’d be able to see how much it’s being used.
Jonathan
October Webinars: Code for Performance
Free Intel webinars can help you accelerate application performance.
Explore tips for MPI, OpenMP, advanced profiling, and more. Get the most from
the latest Intel processors and coprocessors. See abstracts and register >
http://pubads.g.doubleclick.net/gampad/clk?id=60135991&iu=/4140/ostg.clktrk
Geoserver-devel mailing list
David Winslow
Boundless - http://boundlessgeo.com/
On 25 October 2013 16:11, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Fri, Oct 25, 2013 at 5:00 PM, Jonathan Moules <jonathanmoules@anonymised.com> wrote:
Hi Folks,
I was looking in the documentation and I can’t seem to find anything for SLD’s any more. The stuff for the new CSS extensions is there though.
The SLD stuff is there but… has the search box in the documentation ever worked? For anything?
That’s a surprise to me, I always search with Google instead
For example, searching from graphic fill margin option:
https://www.google.it/search?q=geoserver+sld+margin&oq=geoserver+sld+margin&aqs=chrome…69i57j69i60j0l3j69i64.7949j0j4&sourceid=chrome&ie=UTF-8
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
