[Geoserver-devel] Documentation not updated since October 15th
in other threads we discovered that the doc server has been decommisioned and replaced with S3 storage, is that right?
However the documentation build was not updated accordingly, and has been failing since October 15th, e.g.:
https://build.geoserver.org/view/geoserver/job/geoserver-master-live-docs/1285/console
+ rsync -av -e 'ssh -p 7777' target/master/en root@anonymised.com:/var/www/[docs.geoserver.org/htdocs/master](http://docs.geoserver.org/htdocs/master)
ssh: connect to host [docs.geoserver.org](http://docs.geoserver.org) port 7777: Network is unreachable
rsync: connection unexpectedly closed (0 bytes received so far) [sender]
rsync error: unexplained error (code 255) at io.c(600) [sender=3.0.6]
Build step 'Execute shell' marked build as failure
Sending e-mails to: [geoserver-devel@lists.sourceforge.net](mailto:geoserver-devel@lists.sourceforge.net)
If it’s indeed a S3 buckets I’m guessing a command other than rsync is needed, or not?
Maybe something like this (with the right credentials):
https://serverfault.com/questions/754690/rsync-to-aws-s3-bucket
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
I’m still trying to get the new commands (and credentials) to use to update the doc server from our internal devops team.
So, I am tracking the issue, its just taking (a lot) longer than I would have liked.
Torben
On Mon, Nov 5, 2018 at 5:22 AM Andrea Aime <andrea.aime@anonymised.com> wrote:
Geoserver-devel mailing list
Updates to the docbuild are in progress.
Currently, some doc pages (on master/latest) are broken (return a 403), fix still pending.
Torben
On Wed, Nov 7, 2018 at 9:06 AM Torben Barsballe <tbarsballe@anonymised.com> wrote:
Torben
GeoServer docbuilds are now working, and docs are getting updated on the website.
Note that it may take a little while after the doc build for the updates to actually show up on the website.
Torben
On Wed, Nov 7, 2018 at 4:51 PM Torben Barsballe <tbarsballe@anonymised.com> wrote:
Torben
Torben
It’s working fine, thank you!
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
