[Geoserver-devel] Documentation Search
Hi List,
Just thought I should point out that the search facility on the documentation seems to be acting up for the following important searches (they all give 0 results!)
WMS
WFS
TMS
WCS
I’m sure they used to work.
However, these other acronyms do return results:
SLD, WMTS, GWC
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
