[Geoserver-devel] Does cobertura maven plugin properly work for you?
Hi List,
while checking all requirements for GSIP-134 (sufficient test coverage to migrate module from community to extension) I run the cobertura plugin on the modules and I got several errors/exceptions.
Before starting investigating on issues in these modules I simply did a
“mvn cobertura:cobertura” on gs-main and I had same problems.
Tests run: 695, Failures: 3, Errors: 339, Skipped: 2
containing tons of:
testXXX: BeanFactory not initialized or already closed - call ‘refresh’ before accessing beans via the ApplicationContext
Can anyone confirm that or is it only an issue on my side?
Daniele
Ing. Daniele Romagnoli
Senior Software Engineer
Via Poggio alle Viti 1187
Hi Daniele,
don’t know if you already solved this, but anyhow… I had the same issue and tracked it down to a conflict in the xml-apis dependency.
I sorted it out in gs-main’s pom.xml like this:
org.geoserver gs-ows xml-apis xml-apis xml-apis xml-apis 1.4.01
I have not done a full build to confirm this change doesn’t break anything else: if it doesn’t break the build, might be worth to make a permanent fix?
On Fri, Oct 16, 2015 at 12:44 PM, Daniele Romagnoli <daniele.romagnoli@anonymised.com> wrote:
Hi List,
containing tons of:
Daniele
Geoserver-devel mailing list
Best regards,
Stefano Costa
[http://goo.gl/it488V](http://goo.gl/it488V) for more information.
Dott. Stefano Costa
[http://www.geo-solutions.it](http://www.geo-solutions.it)
[http://twitter.com/geosolutions_it](http://twitter.com/geosolutions_it)
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility  for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
On Mon, Oct 19, 2015 at 10:06 AM, Stefano Costa <
stefano.costa@anonymised.com> wrote:
I have not done a full build to confirm this change doesn't break anything
else: if it doesn't break the build, might be worth to make a permanent fix?
Looks like a good plan to me
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
+1 from me too :slight_smile:
On Mon, Oct 19, 2015 at 10:17 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Mon, Oct 19, 2015 at 10:06 AM, Stefano Costa <stefano.costa@anonymised.com> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
After playing with this for a while, I realized it was enough to specify the xml-apis version in the dependencyManagement section of the parent POM.
PR is here:
https://github.com/geoserver/geoserver/pull/1275
On Mon, Oct 19, 2015 at 12:12 PM, Daniele Romagnoli <daniele.romagnoli@anonymised.com> wrote:
On Mon, Oct 19, 2015 at 10:17 AM, Andrea Aime <andrea.aime@anonymised.com…1268…> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
Best regards,
Stefano Costa
Dott. Stefano Costa
D.Lgs. 196/2003.
