hi,
now i read the code of geoserver,i don't find class doc just like jdk help doc,so i am difficult to read it,would you give me some advice and help
From: geoserver-devel-request@lists.sourceforge.net
Reply-To: geoserver-devel@lists.sourceforge.net
Subject: Geoserver-devel digest, Vol 1 #737 - 4 msgs
Date: Wed, 06 Jul 2005 20:11:08 -0700Send Geoserver-devel mailing list submissions to
geoserver-devel@lists.sourceforge.netTo subscribe or unsubscribe via the World Wide Web, visit
or, via email, send a message with subject or body 'help' to
geoserver-devel-request@lists.sourceforge.netYou can reach the person managing the list at
geoserver-devel-admin@lists.sourceforge.netWhen replying, please edit your Subject line so it is more specific
than "Re: Contents of Geoserver-devel digest..."Today's Topics:
1. epgs-hsql problem on 2.1.x? (dblasby@anonymised.com)
2. Re: direction plotting (dblasby@anonymised.com)
3. hi (Omar Zevallos)
4. Re: epgs-hsql problem on 2.1.x? (Martin Desruisseaux)--__--__--
Message: 1
Date: Wed, 6 Jul 2005 10:12:02 -0400
To: martin.desruisseaux@anonymised.com
Cc: geoserver-devel@lists.sourceforge.net
Subject: [Geoserver-devel] epgs-hsql problem on 2.1.x?This message is in MIME format.
---MOQ1120659122b7e02985dfbf94f0cd0a5a5c7c36e5af
Content-Type: text/plain; charset=ISO-8859-1
Content-Transfer-Encoding: 8bit
Content-Disposition: inlineMartin,
I'm trying to build 2.1.x, but I'm unable to build the epsg-hsql
portion. James says that it builds on his machine. Now, I've been
away for about 2 weeks, so what might be happening is that other people
have the tmp/Geotools/<hsql DB> from an old run, and I dont?Here's my error message during the build (from maven):
test:test:
[junit] Running
org.geotools.referencing.factory.epsg.DefaultDataSourceTest
[junit] Tests run: 2, Failures: 0, Errors: 0, Time elapsed: 1.893
sec
[junit] Running
org.geotools.referencing.factory.epsg.HSQLDataSourceTest
[junit] Tests run: 2, Failures: 0, Errors: 2, Time elapsed: 1.362
sec
[junit] [ERROR] TEST
t FAILEDBUILD FAILED
File...... C:\Documents and
Settings\Owner\.maven\cache\maven-test-plugin-1.6.2\
plugin.jelly
Element... fail
Line...... 181
Column.... 54
There were test failures.
Total time: 16 seconds
Finished at: Tue Jul 05 16:32:20 EDT 2005Here's whats included in the test reports
(TEST-org.geotools.referencing.factory.epsg.DefaultDataSourceTest.txt):Jul 5, 2005 4:32:17 PM
org.geotools.referencing.factory.epsg.DefaultDataSourceTest setUp
WARNING: An error occured while setting up the date source for the EPSG
database.
Maybe there is no JDBC-ODBC bridge for the current platform.
No test will be performed for this class.
java.lang.NullPointerException
at java.io.Reader.<init>(Reader.java:61)
at java.io.InputStreamReader.<init>(InputStreamReader.java:80)
at
org.geotools.referencing.factory.epsg.HSQLDataSource.getConnection(HSQLDataSource.java:149)
at
org.geotools.referencing.factory.epsg.HSQLDataSource.createFactory(HSQLDataSource.java:210)
at
org.geotools.referencing.factory.epsg.DefaultFactory.createFactory(DefaultFactory.java:250)
And from
(TEST-org.geotools.referencing.factory.epsg.HSQLDataSourceTest.txt):Testcase:
testCreation(org.geotools.referencing.factory.epsg.HSQLDataSourceTest):
Caused
an ERROR
Failed to connect to the EPSG database
org.opengis.referencing.FactoryException: Failed to connect to the EPSG
database
at
org.geotools.referencing.factory.epsg.DefaultFactory.createBackingStore(DefaultFactory.java:316)
at
org.geotools.referencing.factory.DeferredAuthorityFactory.getBackingStore(DeferredAuthorityFactory.java:127)
I've also attached the test report files.
Any idea what I'm doing wrong?
dave
This mail sent through IMP: https://webmail.limegroup.com/---MOQ1120659122b7e02985dfbf94f0cd0a5a5c7c36e5af
name="TEST-org.geotools.referencing.factory.epsg.DefaultDataSourceTest.txt"
Content-Transfer-Encoding: base64
Content-Disposition: attachment;
filename="TEST-org.geotools.referencing.factory.epsg.DefaultDataSourceTest.txt"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---MOQ1120659122b7e02985dfbf94f0cd0a5a5c7c36e5af
name="TEST-org.geotools.referencing.factory.epsg.HSQLDataSourceTest.txt"
filename="TEST-org.geotools.referencing.factory.epsg.HSQLDataSourceTest.txt"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---MOQ1120659122b7e02985dfbf94f0cd0a5a5c7c36e5af--
--__--__--
Message: 2
Date: Wed, 6 Jul 2005 10:57:12 -0400
To: jason.kahler@anonymised.com
Subject: Re: [Geoserver-devel] direction plottingI saw a demonstration of a route-builder at the recent OSGIS/MUM3
conference - by http://www.camptocamp.com/ if I remember correctly.Its basically a postgis plugin for doing route building. If you wanted
to do this quick-and-dirty, you could try to make a datastore that
returns the actual route geometries back for a request.A perhaps better (but more complex way) would be to make a service that
does the same thing - either returning an image (ie WMS response) or a
set of features (ie. a WFS response).As Gabriel says, there's a spec for doing this...
dave
This mail sent through IMP: https://webmail.limegroup.com/--__--__--
Message: 3
To: <geoserver-devel@lists.sourceforge.net>
Date: Wed, 6 Jul 2005 12:11:36 -0500
Subject: [Geoserver-devel] hiThis is a multi-part message in MIME format.
------=_NextPart_000_000D_01C58223.DB3A6270
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printableHi, I have installed GeoServer 1.2.=20
does it work with MapInfo Files directly (.map, .dat)?
How do I configure the GeoServer so that it works with these files?
Regards.------=_NextPart_000_000D_01C58223.DB3A6270
Content-Type: text/html;
Content-Transfer-Encoding: quoted-printable<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type content=3D"text/html; =
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2800.1498" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>Hi, I have installed GeoServer 1.2. =
</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>does it work with MapInfo Files=20
directly (.map, .dat)?</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>How do I configure the GeoServer so =
that it works=20
with these files?</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Regards.</FONT></DIV>
<DIV> </DIV></BODY></HTML>------=_NextPart_000_000D_01C58223.DB3A6270--
--__--__--
Message: 4
Date: Thu, 07 Jul 2005 09:14:51 +1100
From: Martin Desruisseaux <martin.desruisseaux@anonymised.com>
Organization: Institut de Recherche pour le
=?ISO-8859-1?Q?D=E9veloppemen?=
=?ISO-8859-1?Q?t?=
To: dblasby@anonymised.com
CC: geoserver-devel@lists.sourceforge.net
Subject: [Geoserver-devel] Re: epgs-hsql problem on 2.1.x?dblasby@anonymised.com a =E9crit :
> portion. James says that it builds on his machine.epsg-hsql build on my machine too (I tried both trunk and 2.1 branch,=20
both on Windows and Linux). I noticed that it failed on the nightly=20
build, and I asked 3 days ago for a stack trace. I'm not sure if anyone=20
has see my email "Re: [Geotools-devel] GeoTools Build Report
[2005/07/04=20
23:55]"...
Thanks for the stack trace you just sent. I will look at that right now=20
and try to applies some fix or workaround in the next few hours.Martin.
--__--__--
https://lists.sourceforge.net/lists/listinfo/geoserver-develEnd of Geoserver-devel Digest
_________________________________________________________________
ÏíÓÃÊÀ½çÉÏ×î´óµÄµç×ÓÓʼþϵͳ¡ª MSN Hotmail¡£ http://www.hotmail.com
