[Geoserver-devel] Does the build depend on the state of local geoserver?
I got a strange build failure this morning in gs-main as it found that http://localhost:8080/geoserver had wfs turned off - has the build always relied on the state of my local geoserver or is this new?
Turning the WFS service back on fixed the issue.
Ian
Ian Turton
And now I discover that GWC fails with an “Address already in use” BindException that I haven’t investigated but suspect is 8080.
Ian
Ian
Ian Turton
Ian Turton
Hi Ian,
yeah, there are WFS cascading tests triggering if they find a WFS on port 8080
On Sat, Nov 25, 2017 at 12:56 PM, Ian Turton <ijturton@anonymised.com> wrote:
Ian
Ian Turton
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
Andrea Aime
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
On Sat, Nov 25, 2017 at 1:00 PM, Ian Turton <ijturton@anonymised.com> wrote:
And now I discover that GWC fails with an "Address already in use"
BindException that I haven't investigated but suspect is 8080.
Yes, someone added a test opening a port in GWC lately, it fails if it
cannot allocate the port it wants...
never a great idea to create one of those, but when in need, it should pick
a random port and retry with
others if busy
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
