[Geoserver-devel] double check release revision
So the cite tests are having a terrible time:
  • the cite tests are failing with no apparent change
  • running the test by hand, still tests a revision from the 17th (i.e. 9fcfc634a6f06c1f695d13a53347a9bdd8abd5fb )
Here is the history, showing what revision is set for release, Andrea I think you wanted the next one :frowning:
Fixing location of standard styles, some copyright headers, and some … …
08035094b7 Browse code
aaime authored 4 hours ago
[GEOS-5891] REST config upload fail in path with spaces
3c1af14445 Browse code
aaime authored 21 hours ago
Merge branch ‘master’ of github.com:geoserver/geoserver
3378527afd Browse code
aaime authored a day ago
[GEOS-5890] Expose grid coverage band configuration in GUI
cb22aa2817 Browse code
aaime authored 2 days ago
← here →
Merge pull request #270 from jodygarnett/printing_fix …
9fcfc634a6 Browse code
jodygarnett authored 2 days ago
Preserve structured coverage grid reader nature
3268ee171e Browse code
On Thu, Jul 18, 2013 at 8:25 AM, Jody Garnett <jody.garnett@anonymised.com>wrote:
- the cite tests are failing with no apparent change
Failing locally? Or on the build server?
- running the test by hand, still tests a revision from the 17th (i.e. 9fcfc634a6f06c1f695d13a53347a9bdd8abd5fb
It grabs the latest nightly build and the nighties seem to be failing. I'll
investigate.
*Fixing location of standard styles, some copyright headers, and some … …*
*08035094b7 Browse code *
*aaime authored 4 hours ago*
*[GEOS-5891] REST config upload fail in path with spaces*
*3c1af14445 Browse code *
*aaime authored 21 hours ago*
*Merge branch 'master' of github.com:geoserver/geoserver*
*3378527afd Browse code *
*aaime authored a day ago*
*[GEOS-5890] Expose grid coverage band configuration in GUI*
*cb22aa2817 Browse code *
*aaime authored 2 days ago*
*<-- here -->*
*Merge pull request #270 from jodygarnett/printing_fix …*
*9fcfc634a6 Browse code *
*jodygarnett authored 2 days ago*
*Preserve structured coverage grid reader nature*
*3268ee171e Browse code *
See everything from the browser to the database with AppDynamics
Get end-to-end visibility with application monitoring from AppDynamics
Isolate bottlenecks and diagnose root cause in seconds.
Start your free trial of AppDynamics Pro today!
http://pubads.g.doubleclick.net/gampad/clk?id=48808831&iu=/4140/ostg.clktrk
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
On Thu, Jul 18, 2013 at 8:30 AM, Justin Deoliveira <jdeolive@anonymised.com>wrote:
I'll investigate.
It looks to be the jai-tools upgrade... I couldn't quite follow the
discussion on geotools-devel... is this being resolved?
*<-- here -->*
Justin Deoliveira
Justin Deoliveira
I think it wasn’t pulling in the latest git revision yesterday either when I was trying to test Jody’s changes on Hudson
Ian
Ian Turton
On Thu, Jul 18, 2013 at 8:30 AM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
It looks to be the jai-tools upgrade… I couldn’t quite follow the discussion on geotools-devel… is this being resolved?
Justin Deoliveira
On Thu, Jul 18, 2013 at 8:25 AM, Jody Garnett <jody.garnett@anonymised.com03…> wrote:
It grabs the latest nightly build and the nighties seem to be failing. I’ll investigate.
← here →
Justin Deoliveira
Simone said he would take discussion to GeoServer-devel. Not sure if it was noticed it is holding the release up.
Jody Garnett
On 19/07/2013, at 12:32 AM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
It looks to be the jai-tools upgrade... I couldn't quite follow the discussion on geotools-devel... is this being resolved?
Thanks Andrea - it seems your fix has done the trick and the nightly build is back in the game. I will wait for cite to run before declaring victory.
Removing duplicated class from GEoTools, this should fix the build
824ed7ce39
Jody Garnett
