[Geoserver-devel] downloading source code
Hello,
Where can I download GeoTools 2.3.x source code.
I am trying to download from:
http://svn.geotools.org/geotools/branches/2.3.x/
without any success.
Adit.
Adit:
I believe trunk is geotools 2.3
After you build it, it will show as 2.3-SNAPSHOT
Alex
On 9/15/06, Adit Santokhee <ads@anonymised.com> wrote:
Hello,
Adit.
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job
easier
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
Geoserver-devel mailing list
how did you try downloading it?
Adit Santokhee wrote:
Hello,
Adit.
easier
View this message in context: http://www.nabble.com/downloading-source-code-tf2278583.html#a6333958
Sent from the GeoServer - Dev forum at Nabble.com.
Hi Adit,
It seems the repository is up. Which subversion client are you using?
We also plan to release the first milestone release of 2.3, so in a
couple of days the source will be available for download from the website.
-Justin
Hello,
Adit.
!DSPAM:1004,450ad4cc291041219810056!
Get stuff done quickly with pre-integrated technology to make your job easier
Geotools-devel mailing list
Geotools-devel@lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/geotools-devel
Justin Deoliveira
jdeolive@anonymised.com
The Open Planning Project
http://topp.openplans.org
