Hi Mark,
thanks! Had a look, looks like an improvement to me, the current settings seem sensible.
The PR does not really contain the reformatted files, so to see the difference one has to
check it out and run it locally. Mark, maybe you could put the result of reformat in a separate commit,
so that if changes are needed, it’s possible to wipe it and redo the formatting? (and then force push).
It would help other devs get a quick “before and after” view.
One thing that I’m a bit hesitant about, is that empty lines are getting removed. Sometimes these
lines are used to separate blocks, but the semantics of that is in our head, don’t think it’s possible
to tell the plugin about it.
As another node, I’d suggest trying to run it on the applicationContext files, they also are all over the place formatting wise.
Tried locally with the following modified config:
**/pom.xml
**/applicationContext.xml
**/applicationSecurityContext.xml
Love the result consistency, one thing that might not be too pleasing is that namespace declarations
are now moved all in a single line, so:
becomes:
When editing the file contents the difference is ignorable, but if one had to add a namespace, it would be annoying.
Regards, Andrea Aime
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
