[Geoserver-devel] Dropping Java 8 from main branch
After a bit of guesswork and troubleshooting on windows / Java 11 combo the PR is ready: https://github.com/geoserver/geoserver/pull/6370
Thanks Andrea for doing the heavy lifting on this one; the documentation is already updated to be Java 11 minimum.
Please be advised that when this PR is merged you will require a Java 11 environment for working on the main branch.
Jody Garnett
My understanding is we are waiting for the new year before merging this PR (want to be on hand for those upgrading their dev env to java 11).
Jody Garnett
A status update:
Andrea Aime
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
All green now. Shall we?
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
No complaint, starting to merge, from GeoServer and then backwards. We’ll also have to remove the Java 8 builds from the build server (not sure if I’ll manage today).
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Disable java 8 builds, we should be able to repurpose as java 17 builds?
Jody Garnett
Too late, wiped them out. Java 17 builds can be created by copying over the Java 11 ones though.
Not sure we need them until Java 17 is officially supported though (right now it’s experimental with a large bunch
of “add-opens” to have tests run).
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Aaand… all merged!
We are now running on Java 11 as the minimum. Sending separate mail as a reminder.
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Congrats Andrea and thanks for dedication on this one.
Jody Garnett
Nice to see that merged!
With respect to the build server, the Java 11 builds currently use a dedicated workspace and maven repo (i.e., not the default) - now that Java 8 is dropped, we should move the Java 11 builds over to using the main repo, so they use the same repo as any ancillary builds (and then the Java 17 builds can be set up to use the same local repo config).
Looks like the old java 8 builds are still floating around, just disabled, so it should be relatively straightforward to make that change, when applicable.
Torben
On Thu, Jan 5, 2023 at 10:55 AM Andrea Aime <andrea.aime@anonymised.com> wrote:
On Thu, Jan 5, 2023 at 5:32 PM Jody Garnett <jody.garnett@anonymised.com> wrote:
On Thu, Jan 5, 2023 at 8:18 AM Andrea Aime <andrea.aime@anonymised.com> wrote:
On Wed, Jan 4, 2023 at 5:40 PM Andrea Aime <andrea.aime@anonymised.com> wrote:
On Tue, Jan 3, 2023 at 7:21 PM Andrea Aime <andrea.aime@anonymised.com> wrote:
A status update:
On Tue, Dec 27, 2022 at 9:58 PM Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody Garnett
On Mon, Dec 19, 2022 at 8:26 AM Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody Garnett
Geoserver-devel mailing list
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Jody Garnett
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
