Sure, that sounds fine. I was tempted to suggest leaving the release vpf stuff but it is easy enough to restore from git and we will have a cleaner build with less extraneous cruft.
+1 for the new pull request. I have not tried it, but it looks convincing and we will find out pretty soon.
Kind regards,
Ben.
On 02/09/13 14:06, Jody Garnett wrote:
Thanks Ben, I have updated the pull request. I would like to keep the
implementation in GeoTools as I think this work can be salvaged with a
bit of TLC.
On Mon, Sep 2, 2013 at 4:01 PM, Ben Caradoc-Davies
<Ben.Caradoc-Davies@anonymised.com <mailto:Ben.Caradoc-Davies@anonymised.com>> wrote:
Jody,
+1 for dropping the vpf extensions. However, you also need to remove:
<descriptor>release/ext-vpf.__xml</descriptor>
from src/pom.xml . If this entry is not removed, the assembly step
will likely fail as the pom references a file that you have removed.
Kind regards,
Ben.
On 02/09/13 13:49, Jody Garnett wrote:
I had a chance to test the VPF DataStore today, turns out the
tests have
been commented out for some time.
The DataStore implementation was not updated to the GeoTools 2.5
feature
model, so while it compiles, is is never able to serve up any
features.
Actions:
- reopened https://jira.codehaus.org/__browse/GEOT-2347
<https://jira.codehaus.org/browse/GEOT-2347>
- issued a pull request to remove this format
https://github.com/geoserver/__geoserver/pull/312
<https://github.com/geoserver/geoserver/pull/312>
If I can ask for a review of the above pull request please.
Jody
------------------------------__------------------------------__------------------
Learn the latest--Visual Studio 2012, SharePoint 2013, SQL 2012,
more!
Discover the easy way to master current and previous Microsoft
technologies
and advance your career. Get an incredible 1,500+ hours of
step-by-step
tutorial videos with LearnDevNow. Subscribe today and save!
http://pubads.g.doubleclick.__net/gampad/clk?id=58040911&iu=__/4140/ostg.clktrk
<http://pubads.g.doubleclick.net/gampad/clk?id=58040911&iu=/4140/ostg.clktrk>
_________________________________________________
Geoserver-devel mailing list
Geoserver-devel@anonymised.com
<mailto:Geoserver-devel@lists.sourceforge.net>
https://lists.sourceforge.net/__lists/listinfo/geoserver-devel
<https://lists.sourceforge.net/lists/listinfo/geoserver-devel>
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer
CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
Software Engineer
