I have a requirement to create a dynamic featureType for each http
session. Now the geoserver can only create a featureType from a postGis
table via the admin UI.I'm just wondering if there are any ways I can
create a featureType inside a java servlet from a sql select statement
result. I know I may use geotools to create a new featureType. But this
method seems cannot change the cooresponding config file in geoserver.
Any sugegstions to me?
Thanks
Rong
I don't quite understand 'for each http session'? Creating a featureType
from a sql select statement result is more like a dynamic 'view'. Social
Change Online has done some work trying out things like this, and Gabriel
is going to be working the next couple months to get some of their changes
in geoserver 'for real'. Right now your best option is to just create a
view in PostGIS, and use that as a featureType (having a field named 'oid'
helps, or making a primary key on the view, and you'll need to register
the geometry in the geometry_columns table). If you're talking something
more dynamic I'd like to hear more specifics about your use case. We
probably don't support it, but we could try to in the future.
best regards,
Chris
Thanks
Rong-------------------------------------------------------
SF.Net email is sponsored by: Discover Easy Linux Migration Strategies
from IBM. Find simple to follow Roadmaps, straightforward articles,
informative Webcasts and more! Get everything you need to get up to
speed, fast. http://ads.osdn.com/?ad_idt77&alloc_id492&op=click
Geoserver-devel mailing list
Hi, Chris,
My usecase is as below. We are building a yield tracker website based on
geoserver. The farmer can access this website and select a field and
submit a request for predicting the yield of products planted in that
field. We want build a yield layer over the field geograpgic map with
color for different yield value.We have a legacy program to get the UTM
coordinates of the selcted field and other related information input and
return the yield value for each points inside the selected field by
farmer. Now I'm thinking about to build yield layer for each pionts and
display this layer over the filed gis map. When each farmer send a yield
prediction request for the selected layer, there is a return result from
the legacy program and we need generate a dynamic yield layer for the
select field.At the same time, another farmer will select another field
and send another prediction request and get another yield layer of his
selected field. All these are dynamic. I also think that we can create a
view for each yield prediction request. In this case, we also need
create a dynamic featureType for each cooresponding prediction request
and return the right wms getmap url with the generated layer name to the
client. If you still have any questions about this,PLS let me know.
I'm think of creating the featureType from the dynamic view on the fly
using the admin interface inside a java program. Is this feasible?
Thank you very much for any suggestions
Best,
Any sugegstions to me?I don't quite understand 'for each http session'? Creating a featureType
probably don't support it, but we could try to in the future.best regards,
Chris
Thanks
https://lists.sourceforge.net/lists/listinfo/geoserver-devel--
Thanks for your suggestions. But I still have some questions as below:
Rather than create a new featureType for each prediction, I'd think it
would be easier to create a static featureType with an attribute that
identified the prediction and then just select the features which have
that
value.
How can I select the festures with the points inside the selected field
and use the static featureType with an attribute to create a different
layer for different prediction request?
Or are the attributes (types, not values) different for each
prediction?
Here is a simple version of the table structure:
oid:serial | plant_categories: int | the_yield:int| the_ponit:point |
plant_date : date | the_geom:geometry
each UTM point has a record in this table.I just need select the points
with in a selected field and with the right plant_categories and right
plant_date for the repdiction request.
At 04:33 PM 6/27/2005, you wrote:
Hi, Chris,
on
Best,>> Hi,
postGis
statement
this
geoserver.
featureType
Social
Gabriel
changes
a
'oid'
register
something
> best regards,
> Chris
>> Thanks
>> Rong
Strategies
>> _______________________________________________
speed, fast. http://ads.osdn.com/?ad_idt77&alloc_id492&opick
hi,
it seems to me that you are not creating new feature _types_ but new _instances_, and the current mapping of a result set to a feature type is too restrictive.
We have a project underway, as Chris said, to decouple the result set from a single table/view and allow it to be mapped to an arbitrary output. I think this could be used fairly easily against a defined function to achieve this sort of outcome.
(from later emails I see that you probably just need to create the correct query filter). Only quaestion is why the data structure appears to have two geometries - this is OK in GML world, not sure if geoserver will handle it well though. The real issue, like that of featuretypes versus instances is one of transparency: the_point and the_geom tell the user nothing about the semantics of the attribute, but merely reflect and duplicate information already available in the GML:geometry enclosed in these attributes.
Best to use pre-defined semantics such as gml:pos or gml:envelope or make your own up _ONLY IF THERE IS NO EQUIVALENT AVAILABLE!!!_ - such as myns:nearestPostOfficeLocation
the ability to actually use gml predefined semantics might require the schema output mapping technology we are putting into the product, so in the meantime you could use myns:pos and declare it to be equal via a XML schema substitution group. If you are not going to expose your "featureType" to external parties these issues may not be significant, but they lie at the root of creating stable interoperable solutions across enterprise boundaries.
Rob Atkinson
rong@anonymised.com wrote:
Hi, Chris,
Best,Hi,
Chris
Thanks
speed, fast. http://ads.osdn.com/?ad_idt77&alloc_id492&opÌk
Quoting rong@anonymised.com:
Hi, Chris,
based on
UTM
and
and
yield
from
field
his
create a
request
the
fly
Yes, this is definitely feasible, and I think the way to go now, before
we get Rob's improvements in. See:
http://docs.codehaus.org/display/GEOSDOC/Alternative+for+reloading+the+Geoserver+catalog
for how to force the reload from code. And I think the way these guys
did is to just make a new config xml file. The other possibility is
working with the DTO objects directly - they hold the config, and you
can just modify and reload with them.
best regards,
Chris
Best,>> Hi,
http
postGis
can
statement
this
geoserver.
featureType
Social
Gabriel
changes
create a
named 'oid'
register
something
We
> best regards,
> Chris
>> Thanks
>> Rong
Strategies
articles,
to
Strategies
This mail sent through IMP: https://webmail.limegroup.com/
Hi, Rob and Chris,
Thank you very much for your suggestions. Like Rob said, I just realized
that I only need to create new feature instance dynamically instead of
create new featureType dynamically. I think I can use the filter query
in the SLD file for each http request session. So each prediction
requestion will come with SLD file with the right filter query for the
slected field. Can the geoserver(wms) generate the map layer from
different filter query and the same featureType for different prediction
reuqests? I assume it can. I'll test it.
For the two geometries in the table, i just use the PostgresSQL point
types but not the PostGIS geometry type for "the_point". I keep this
information redundency just for performance concern. The yield value is
generated by other legacy application which very slow. I'm thinking
about to cache the yield value in the database. In the future, if a
prediction request come, I'll check the DB first see if there has a
yield value for the selected field. If there has, just get it from DB.
And I know that the performance of the geometry function from PostGIS is
not good. So I just keep this PostgresSQL point type for performance
concern.
Thanks again.
Rong.
hi,
is too restrictive.We have a project underway, as Chris said, to decouple the result set
function to achieve this sort of outcome.(from later emails I see that you probably just need to create the
in these attributes.Best to use pre-defined semantics such as gml:pos or gml:envelope or
myns:nearestPostOfficeLocationthe ability to actually use gml predefined semantics might require the
across enterprise boundaries.Rob Atkinson
Hi, Chris,
on
Best,Hi,
featureType
Social
Gabriel
changes
'oid'
something
Chris
Thanks
https://lists.sourceforge.net/lists/listinfo/geoserver-devel-------------------------------------------------------
speed, fast. http://ads.osdn.com/?ad_id=7477&alloc_id=16492&op=click
