[Geoserver-devel] Early backport of GEOS-10012 Support inclusion vendor option to disable Style elements when rendering legends
Dear all,
I’m writing to ask permission for early backport of GEOS-10012 Support inclusion vendor options to disable Style elements when rendering legends.
The new functionality allows to disable Style elements when rendering by means of a VendorOption that can be defined at the FeatureTypeStyle, Rule or Symbolizer level.
No backward compatibility issue is foreseen since the option to have any effect needs to be explicitly provided by the user in the SLD, while by default legend rendering works as usual. Details in the related Jira ticket linked above.
Best regards,
Marco Volpini
+1
Nuno Oliveira
Visit http://goo.gl/it488V for more information.
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Software Engineer
Via di Montramito 3/A
Con riferimento alla normativa sul trattamento dei dati
personali (Reg. UE 2016/679 - Regolamento generale sulla
protezione dei dati “GDPR”), si precisa che ogni
circostanza inerente alla presente email (il suo contenuto,
gli eventuali allegati, etc.) è un dato la cui conoscenza
è riservata al/i solo/i destinatario/i indicati dallo
scrivente. Se il messaggio Le è giunto per errore, è
tenuta/o a cancellarlo, ogni altra operazione è illecita.
Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to
which it is addressed and may contain information that
is privileged, confidential or otherwise protected from
disclosure. We remind that - as provided by European
Regulation 2016/679 “GDPR” - copying, dissemination or
use of this e-mail or the information herein by anyone
other than the intended recipient is prohibited. If you
have received this email by mistake, please notify
us immediately by telephone or e-mail.
