Dear all,
I’m writing to ask permission for early backport of GEOS-10028 Allow to customize ComplexGeoJsonWriter encoding of nested element and non mandatory attributes.
The pr introduced an extension point in the ComplexGeoJsonWriter to allows to customize the complex features GeoJSON encoding with respect to non mandatory attributes.
By default the encoding mechanism has been left as before and no backward compatibility issue is foreseen. Details are on the Jira ticket linked above.
Best regards,
Marco Volpini
+0
Simone Giannecchini
Visit http://bit.ly/gs-services for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
GeoSolutions
Via di Montramito 3/A
mob: +39 333 8128928
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
+1 this is an isolated addition that adds an extension point.
Nuno Oliveira
Visit http://goo.gl/it488V for more information.
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Software Engineer
