[Geoserver-devel] Early backport of [GEOS-9804] -The default style of the layergroup is propagated in the layer as default style
Dear all,
I’m writing to ask permission for early backport of [GEOS-9804]-The default style of the layer group is propagated in the layer as default style.
The ticket signaled problems in WMS clients caused by layer Group default style in capabilities, if the group mode is a tree one.
The related pr adds an option on the WMS settings page to disable the addition of the default style for layer group with modes different from single and opaque.
No backwards compatibility issue is foreseen as by default the option is set to enabled. Details are on the JIRA ticket (https://osgeo-org.atlassian.net/browse/GEOS-9804) and on the related pr.
Best regards,
Marco Volpini
+1
Ian
Ian Turton
+0
Simone Giannecchini
Visit http://bit.ly/gs-services for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
GeoSolutions
Via di Montramito 3/A
mob: +39 333 8128928
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
+0
Regards, Andrea Aime
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Macro:
The ticket is marked as a bug, no reason to wait when backporting bug fixes.
Q: Did you mean to mark this as a new feature or improvement?
Jody Garnett
Thanks for your point Jody:
the reporter marked it as a bug, but its resolution implied the addition of a new option from UI, that’s why I’m asking early backport permission.
I marked it as new function to avoid confusion.
Best regards,
Marco Volpini
Il giorno mer 26 mag 2021 alle ore 17:51 Jody Garnett <jody.garnett@anonymised.com> ha scritto:
Macro:
Jody Garnett
On Wed, 26 May 2021 at 00:18, Marco Volpini <marco.volpini@anonymised.com> wrote:
Dear all,
Best regards,
Marco Volpini
Geoserver-devel mailing list
+1
Torben
On Wed, May 26, 2021 at 12:18 AM Marco Volpini <marco.volpini@anonymised.com> wrote:
Dear all,
Best regards,
Marco Volpini
