I’ve just merged on main a PR adding a new tab in the status page, that allows admins to get a stack trace of the server.
This is pretty handy in environments where getting a SSH connection is hard or just requires a lot of bureaucracy.
I’m asking for an early backport on 2.21.x, and maybe even on 2.20.x, given its practical usefulness. I have got the backport bot to generate the PRs so you’ll see them out there, but waiting for approval (or not) on this mail. The only way to make the bot generate the PRs, is to do so on merge, cannot make it do them later.
Andrea Aime
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 333 8128928
