[Geoserver-devel] Early backport request - [GEOS-10507] GeoFence Internal - Support Batch operations for Rules and AdminRules
Dear all,
I’m writing to ask permission for an early backport of [GEOS-10507] GeoFence Internal - Support Batch operations for Rules and AdminRules to 2.20.x and 2.21.x.
The pr added a REST endpoint to perform multiple insert,update,delete operations over Rules and AdminRules in the GeoFence Internal extension (as it is currently possible to do with the stand alone version). The code modification is purely additive and no backward compatibility issue is foreseen.
Marco Volpini
Visit http://bit.ly/gs-services-us for more information.
Marco Volpini
Software Engineer
GeoSolutions Group
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Hi Marco,
looks isolated enough for me, +1.
Kind regards,
Nuno Oliveira
Nuno Oliveira
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Technical Lead / Project Manager
GeoSolutions Group
