[Geoserver-devel] Eclipse configuration to debug extensions?
Hello –
I followed the directions available at
http://docs.geoserver.org/stable/en/developer/quickstart/index.html
http://docs.geoserver.org/stable/en/developer/maven-guide/index.html
http://docs.geoserver.org/stable/en/developer/eclipse-guide/index.html
… and was easily able to end up with a debug-able environment in Eclipse. Thank you! This documentation is soooo much better than some other geospatial opensource projects I’ve dealt with….
My question though, is what do I have to do to be able to debug extensions? I did “mvn clean install –P allExtensions” and then pointed my Eclipse environment to a custom data directory (specifically, the app-schema tutorial directory). However it appears that when I run/debug the thing, the app-schema extension is not being used.
Is there an “easy way” to get that set up? I’m just an Eclipse beginner, but I’m pretty good at following directions…
Thanks!
Ryan
I think you need to do mvn eclipse:eclipe -P allExtensions; the profile will be used with the .project and .classpath files are generated; from there on out you can debug from eclipse like normal.
Jody
On 31/07/2010, at 7:38 AM, Ryan Clark wrote:
Hello –
Thanks!
Ryan
The Palm PDK Hot Apps Program offers developers who use the
Plug-In Development Kit to bring their C/C++ apps to Palm for a share
of $1 Million in cash or HP Products. Visit us here for more details:
http://p.sf.net/sfu/dev2dev-palm_______________________________________________
Geoserver-devel mailing list
Hello –
Thanks!
Ryan
Hello –
Thanks!
Ryan
There is documentation about how we integrate community modules and extensions here:
http://docs.geoserver.org/stable/en/developer/policies/community-modules.html
it walks through the process of how to update the source tree to get an extension included. That should help.
-Justin
On 10-07-30 2:38 PM, Ryan Clark wrote:
Hello –
Thanks!
Ryan
Justin Deoliveira
OpenGeo - http://opengeo.org
