[Geoserver-devel] Eclipse google format plugin 4 spaces indentation on documentation.
Hi all.
As I see on dev documentation, there is not ‘official’ support for 4-spaces-indentation on Google-format-plugin for Eclipse.
https://docs.geoserver.org/latest/en/developer/eclipse-guide/index.html#code-formatting
I recently compiled a default 4 spaces indentation branch and tested it with Eclipse 2018-12 Enterprise Java IDE and works fine, it can be downloaded from:
https://github.com/fernandor777/google-java-format/releases/download/1.7-gsgt/google-java-format-eclipse-plugin-1.6.0.jar
Branch:
https://github.com/fernandor777/google-java-format/tree/geoserver
I was wondering if it’s good idea to add this version on Geoserver developer documentation? Probably this plugin could be useful for anyone else using Eclipse :slight_smile:
Fernando Mino
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Fernando Mino
Software Engineer
Via di Montramito 3/A
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Yes, please. Can you add it to GeoTools (or link it somehow) too?
Ian
Ian Turton
Yes of course, I guess it should be appended on Use of Formatting Tools section in:
http://docs.geotools.org/latest/developer/conventions/code/style.html
Fernando Mino
Ian Turton
