On Mon, Oct 6, 2014 at 3:37 PM, Gergely Padányi-Gulyás <fegyi001@...403...>
wrote:
Dear Developers!
I'm developing a new plugin for GeoServer. I am also a newbie to GeoServer
development. I am through the first steps (creating a jar, put it into
webapps/geoserver/WEB-INF/lib directory, everything works fine), but I'm
stuck here with debugging the plugin.
It is a long and exhausting procedure making any changes alive:
1. make the desired changes
2. run "mvn install" to create the jar
3. stop geoserver
4. overwrite the jar in the WEB-INF/lib directory
5. start geoserver
6. geoserver login
7. observe the log window (in a simple cmd terminal, I use Windows and
start geoserver from this terminal using start.bat)
Does anyone have a better way to debug and make the development more
efficient? I use Eclipse Luna 4.4.0
I'm not sure it will work, but try this:
* Add web-app as a test dependency in your plugin module,
* Copy the jetty test dependencies from web-app
into your module as test dependencies,
* Copy the Start.java class from web-app among your tests
This should be enough (maybe with some variation/extra steps) to start
GeoServer with your custom module inside.
Or, as an alternative and if your module is of general interest, open your
module to the community by making a community module, and we'll
create a profile to include it int the build on demand
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
