Hi there,
this is on main with geofence-server.
I wonder what is the actually expected encoding for Geofence Jaxb objects. For example, the output of /geoserver/rest/geofence/rules will give something like the xml fragment below, which doesn’t match the annotations in JaxbRuleList etc such as:
@XmlRootElement(name = “Rules”) public class JaxbRuleList …
@XmlRootElement(name = “Rule”) public class JaxbRule…
2
2
0
ROLE_EDITOR
ALLOW
As far as I can see the controller is tested directly but can’t find a test that checks on the output encoding.
Gabriel Roldán
