[Geoserver-devel] EMF Bindings strange behavior
I’m trying to create a new binding for the GML EnvelopeType as a JTS Envelope, since I couldn’t use geotools gml2/3 EMF models due to some specific Elements defined only for WCS 1.0.0.
Nevertheless I followed the implementation of the existing gt-GML3 module EvnelopeTypeBinding, returning a ReferencedEnvelope object as result of the EnvelopeTypeBinding parsing.
Now … all seems working fine until I try to parse a WCS 1.0.0 SpatialSubsetType … here I get an exception like the following:
org.vfny.geoserver.wcs.WcsException: Parsing failed, the xml request is most probably not compliant to the wcs schema
at org.geoserver.wcs.xml.v1_0_0.WcsXmlReader.read(WcsXmlReader.java:50)
at org.geoserver.wcs.xml.GetCoverageXmlParserTest.testBasic(GetCoverageXmlParserTest.java:86)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.jdt.internal.junit.runner.junit3.JUnit3TestReference.run(JUnit3TestReference.java:130)
at org.eclipse.jdt.internal.junit.runner.TestExecution.run(TestExecution.java:38)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:460)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:673)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:386)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main(RemoteTestRunner.java:196)
Caused by: java.lang.RuntimeException: Parsing failed for spatialSubset: java.lang.RuntimeException: Unable to set property: Envelope for eobject: {http://www.opengis.net/wcs}SpatialSubsetType
at org.geotools.xml.impl.ParseExecutor.visit(ParseExecutor.java:152)
at org.geotools.xml.impl.BindingWalker$BindingExecutionChain.execute(BindingWalker.java:208)
at org.geotools.xml.impl.BindingWalker.walk(BindingWalker.java:174)
at org.geotools.xml.impl.ElementHandlerImpl.endElement(ElementHandlerImpl.java:222)
at org.geotools.xml.impl.ParserHandler.endElement(ParserHandler.java:582)
at org.apache.xerces.parsers.AbstractSAXParser.endElement(Unknown Source)
at org.apache.xerces.impl.xs.XMLSchemaValidator.endElement(Unknown Source)
at org.apache.xerces.impl.XMLNSDocumentScannerImpl.scanEndElement(Unknown Source)
at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl$FragmentContentDispatcher.dispatch(Unknown Source)
at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
at org.apache.xerces.parsers.XML11Configuration.parse(Unknown Source)
at org.apache.xerces.parsers.XMLParser.parse(Unknown Source)
at org.apache.xerces.parsers.AbstractSAXParser.parse(Unknown Source)
at org.geotools.xml.Parser.parse(Parser.java:180)
at org.geotools.xml.Parser.parse(Parser.java:158)
at org.geoserver.wcs.xml.v1_0_0.WcsXmlReader.read(WcsXmlReader.java:48)
… 19 more
Caused by: java.lang.RuntimeException: Unable to set property: Envelope for eobject: {http://www.opengis.net/wcs}SpatialSubsetType
at org.geotools.xml.AbstractComplexEMFBinding.setProperty(AbstractComplexEMFBinding.java:271)
at org.geotools.xml.AbstractComplexEMFBinding.setProperties(AbstractComplexEMFBinding.java:202)
at org.geotools.xml.AbstractComplexEMFBinding.parse(AbstractComplexEMFBinding.java:143)
at org.geotools.xml.impl.ParseExecutor.visit(ParseExecutor.java:143)
… 35 more
Caused by: java.lang.ClassCastException: The feature 'envelope’s type ‘EnvelopeType’ does not permit a value of type ‘org.geotools.geometry.jts.ReferencedEnvelope’
at org.eclipse.emf.ecore.impl.EStructuralFeatureImpl$BasicFeatureMapEntry.validate(EStructuralFeatureImpl.java:2843)
at org.eclipse.emf.ecore.util.FeatureMapUtil.createEntry(FeatureMapUtil.java:146)
at org.eclipse.emf.ecore.util.BasicFeatureMap.createEntry(BasicFeatureMap.java:94)
at org.eclipse.emf.ecore.util.BasicFeatureMap.addAll(BasicFeatureMap.java:1253)
at org.eclipse.emf.ecore.util.FeatureMapUtil$FeatureEList.addAll(FeatureMapUtil.java:656)
at org.geotools.xml.EMFUtils.add(EMFUtils.java:93)
at org.geotools.xml.AbstractComplexEMFBinding.setProperty(AbstractComplexEMFBinding.java:230)
… 38 more
And if I return an EvnelopeType all works well …
any ideas? am I missing something? Do I have to build a geotools converter or something like that?
Any help kindly appreciated.
Alessio.
Eng. Alessio Fabiani
Vice-President /CTO GeoSolutions S.A.S.
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 349 8227000
I guess if the binding declares it returns ReferencedEnvelope.class in
getType() it should be respected...
like in class EnvelopeTypeBinding extends AbstractComplexTypeBinding{
public Class getType() {
        return ReferencedEnvelope.class;
though not sure that is the solution actually...
Gabriel
On Thursday 10 July 2008 03:43:30 pm Alessio Fabiani wrote:
I'm trying to create a new binding for the GML EnvelopeType as a JTS
Envelope, since I couldn't use geotools gml2/3 EMF models due to some
Now ... all seems working fine until I try to parse a WCS 1.0.0
SpatialSubsetType ... here I get an exception like the following:
    at
erTest.java:86) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native
Method) at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) at
sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at
    at
TestReference.java:130) at
38) at
unner.java:460) at
unner.java:673) at
.java:386) at
r.java:196) Caused by: java.lang.RuntimeException: Parsing failed for
for eobject: { http://www.opengis.net/wcs\}SpatialSubsetType
    at
lker.java:208) at
org.geotools.xml.impl.BindingWalker.walk(BindingWalker.java:174) at
:222) at
Source)
Source)
    at
Source)
    at
    at
Source)
    ... 19 more
eobject: {http://www.opengis.net/wcs\}SpatialSubsetType
    at
nding.java:271) at
Binding.java:202) at
java:143) at
org.geotools.xml.impl.ParseExecutor.visit(ParseExecutor.java:143) ... 35
more
Caused by: java.lang.ClassCastException: The feature 'envelope's type
'EnvelopeType' does not permit a value of type
'org.geotools.geometry.jts.ReferencedEnvelope'
    at
date(EStructuralFeatureImpl.java:2843) at
46) at
:94) at
) at
l.java:656) at org.geotools.xml.EMFUtils.add(EMFUtils.java:93)
    at
nding.java:230) ... 38 more
And if I return an EvnelopeType all works well ...
            Alessio.
Hi Gabriel,
thanks for the response … I have already inspected this possibility, but does not seem to solve the problem … I also tryied several WCSConfiguration and GMLConfiguration combinations … but I got no successful result.
The only thing I noticed is that the AbstractComplexEMFBinding superclass fails on the setProperty method trying to instantiate a geotools.util.Converter from the expected EnvelopeType class to jts.Envelope (or ReferencedEnvelope) one, since no one exists … the only thing I cannot really figure out is why that works for gt-GML3 module and not for mine since they are almost equal !!!
On Thu, Jul 10, 2008 at 4:06 PM, Gabriel Roldán <groldan@anonymised.com> wrote:
getType() it should be respected…
though not sure that is the solution actually…
Gabriel
at
at
38) at
unner.java:460) at
unner.java:673) at
.java:386) at
for eobject: { http://www.opengis.net/wcs}SpatialSubsetType
at
lker.java:208) at
:222) at
Source)
Source)
at
Source)
at
at
Source)
… 19 more
at
nding.java:271) at
java:143) at
org.geotools.xml.impl.ParseExecutor.visit(ParseExecutor.java:143) … 35
more
at
  1. at
:94) at
) at
at
nding.java:230) … 38 more
Alessio.
Sponsored by: SourceForge.net Community Choice Awards: VOTE NOW!
Studies have shown that voting for your favorite open source project,
along with a healthy diet, reduces your potential for chronic lameness
and boredom. Vote Now at http://www.sourceforge.net/community/cca08
Geoserver-devel mailing list
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Well, finally I got the solution … just for knowledge I will briefly share the solution with the community, soon I will update the tutorial that I have written for the EMF model generation, adding the binding implementation also.
A bit of introduction first.
The WCS 1.0.0 schema for the DomainSubset part requires a structure like the following:
wcs:domainSubset
wcs:spatialSubset
<gml:Envelope srsName=“EPSG:32633”>
gml:pos347649.93086859107 5176214.082539256</gml:pos>
gml:pos370725.976428591 5196961.352859256</gml:pos>
</gml:Envelope>
<gml:Grid dimension=“2” srsName=“EPSG:4326”>
gml:limits
gml:GridEnvelope
gml:low0 0</gml:low>
gml:high545 490</gml:high>
</gml:GridEnvelope>
</gml:limits>
</gml:Grid>
</wcs:spatialSubset>
</wcs:domainSubset>
As you can notice the domainSubset and the spatialSubset nodes belong to the “wcs” namespace, while the Envelope and Grid to the “gml” one instead.
That means that the EnvelopeBinding and GridBinding have to be implemented into some “gt-gml” (just a dummy name) module and the spatialSubsetBinding and domainSubsetBinding have to be implemented into some “gt-wcs” package instead.
At this point we have several ways to do that, but particular attention has to be put on how we implement the WCSConfiguration and GMLConfiguration for both the WCS and GML binding packages (more details later).
Method 1: if you would like the Parser to automatically populate the objects, than you must leave the EnvelopeBinding and the GridBinding respectively return the EMF Objects (EObjects) EnvelopeType and GridType.
Method 2: if you would like to allow the EnvelopeBinding returning for instance a geotools GeneralEnvelope (or a JTS Envelope or whatelse), than you MUST say to the WCS spatialSubsetBinding and to the domainSubsetBinding how to handle such case. You have here several ways too. One would be to write some specific geotools Converters from EnvelopeType to whatelse; another one, easier, would be to manually rewrite te “parse” methods of the spatialSubsetBinding and domainSubsetBinding in order to handle the GeneralEnvelope parsing. The latter is for sure the best path to follow … but you have to pay particular attention on how you write the WCSConfiguration binding file, infact you have to explicitly register both the spatialSubsetBinding and the domainSubsetBinding implementations as represented below.
bindings.put(WCS.DomainSubsetType, new DomainSubsetTypeBinding());
bindings.put(WCS.SpatialSubsetType, new SpatialSubsetTypeBinding());
Alessio.
On Thu, Jul 10, 2008 at 4:18 PM, Alessio Fabiani <alessio.fabiani@anonymised.com> wrote:
Hi Gabriel,
On Thu, Jul 10, 2008 at 4:06 PM, Gabriel Roldán <groldan@anonymised.com…1501…> wrote:
Gabriel
at
at
38) at
unner.java:460) at
unner.java:673) at
.java:386) at
at
lker.java:208) at
:222) at
Source)
Source)
at
Source)
at
at
Source)
… 19 more
at
nding.java:271) at
java:143) at
more
at
  1. at
:94) at
) at
at
Alessio.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Hi Alessio,
It sounds like you found a away around your problem. But a possible third solution:
3. Change the generated class SpatialSubsetType "manually" so that its Envelope property is actually of the type geotools type envelope. I call this "instrumenting" the model.
Then the GML bindings should parse the Envelope, and the reflective EMF bindings should still be able to reflectivley set the property.
-Justin
Well, finally I got the solution .... just for knowledge I will briefly share the solution with the community, soon I will update the tutorial that I have written for the EMF model generation, adding the binding implementation also.
    <wcs:domainSubset>
        <wcs:spatialSubset>
            <gml:Envelope srsName="EPSG:32633">
                <gml:pos>347649.93086859107 5176214.082539256</gml:pos>
                <gml:pos>370725.976428591 5196961.352859256</gml:pos>
            </gml:Envelope>
            <gml:Grid dimension="2" srsName="EPSG:4326">
                <gml:limits>
                    <gml:GridEnvelope>
                        <gml:low>0 0</gml:low>
                        <gml:high>545 490</gml:high>
                    </gml:GridEnvelope>
                </gml:limits>
            </gml:Grid>
    </wcs:domainSubset>
As you can notice the domainSubset and the spatialSubset nodes belong to the "wcs" namespace, while the Envelope and Grid to the "gml" one instead.
That means that the EnvelopeBinding and GridBinding have to be implemented into some "gt-gml" (just a dummy name) module and the spatialSubsetBinding and domainSubsetBinding have to be implemented into some "gt-wcs" package instead.
Method 2: if you would like to allow the EnvelopeBinding returning for instance a geotools GeneralEnvelope (or a JTS Envelope or whatelse), than you MUST say to the WCS spatialSubsetBinding and to the domainSubsetBinding how to handle such case. You have here several ways too. One would be to write some specific geotools Converters from EnvelopeType to whatelse; another one, easier, would be to manually rewrite te "parse" methods of the spatialSubsetBinding and domainSubsetBinding in order to handle the GeneralEnvelope parsing. The latter is for sure the best path to follow ... but you have to pay particular attention on how you write the WCSConfiguration binding file, infact you have to explicitly register both the spatialSubsetBinding and the domainSubsetBinding implementations as represented below.
                Alessio.
On Thu, Jul 10, 2008 at 4:18 PM, Alessio Fabiani <alessio.fabiani@anonymised.com <mailto:alessio.fabiani@anonymised.com>> wrote:
    Hi Gabriel,
    thanks for the response ... I have already inspected this
    possibility, but does not seem to solve the problem ... I also
    ... but I got no successful result.
    jts.Envelope (or ReferencedEnvelope) one, since no one exists ...
        Gabriel
         > Hi all,
         > I'm trying to create a new binding for the GML EnvelopeType
        as a JTS
         > Envelope, since I couldn't use geotools gml2/3 EMF models due
        to some
         > specific Elements defined only for WCS 1.0.0. <http://1.0.0.>
         > Nevertheless I followed the implementation of the existing
        gt-GML3 module
         > EvnelopeTypeBinding, returning a ReferencedEnvelope object as
        result of the
         > EnvelopeTypeBinding parsing.
         > Now ... all seems working fine until I try to parse a WCS 1.0.0
         > SpatialSubsetType ... here I get an exception like the following:
         > org.vfny.geoserver.wcs.WcsException: Parsing failed, the xml
        request is
         > most probably not compliant to the wcs schema
         > at
         > at
         >erTest.java:86) at
         > Method) at
         > sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown
        Source) at
         > java.lang.reflect.Method.invoke(Unknown Source)
         > at junit.framework.TestCase.runTest(TestCase.java:164)
         > at junit.framework.TestCase.runBare(TestCase.java:130)
         > at junit.framework.TestResult$1.protect(TestResult.java:106)
         > at
         > at junit.framework.TestResult.run(TestResult.java:109)
         > at junit.framework.TestCase.run(TestCase.java:120)
         > at junit.framework.TestSuite.runTest(TestSuite.java:230)
         > at junit.framework.TestSuite.run(TestSuite.java:225)
         > at
         >TestReference.java:130) at
         >38) at
         >unner.java:460) at
         >unner.java:673) at
         >.java:386) at
         >r.java:196) Caused by: java.lang.RuntimeException: Parsing
        failed for
         > spatialSubset: java.lang.RuntimeException: Unable to set
        property: Envelope
         > for eobject: { http://www.opengis.net/wcs\}SpatialSubsetType
        <http://www.opengis.net/wcs}SpatialSubsetType&gt;
         > at
         > at
         >lker.java:208) at
         >:222) at
         > at
         > Source)
         > at
         > Source)
         > at
         > Source)
         > at
         >cher.dispatch(Unknown Source)
         > at
         > Source)
         > at
         > at
         > at org.apache.xerces.parsers.XMLParser.parse(Unknown Source)
         > at
         > at org.geotools.xml.Parser.parse(Parser.java:180)
         > at org.geotools.xml.Parser.parse(Parser.java:158)
         > at
         > ... 19 more
         > Caused by: java.lang.RuntimeException: Unable to set
         > eobject: {http://www.opengis.net/wcs\}SpatialSubsetType
         > at
         >nding.java:271) at
         >Binding.java:202) at
         >java:143) at
        ... 35
         > more
         > Caused by: java.lang.ClassCastException: The feature
        'envelope's type
         > 'EnvelopeType' does not permit a value of type
         > 'org.geotools.geometry.jts.ReferencedEnvelope'
         > at
         >date(EStructuralFeatureImpl.java:2843) at
         >46) at
         >:94) at
         >) at
         >l.java:656) at org.geotools.xml.EMFUtils.add(EMFUtils.java:93)
         > at
         >nding.java:230) ... 38 more
         > And if I return an EvnelopeType all works well ...
         > any ideas? am I missing something? Do I have to build a
        geotools converter
         > or something like that?
         > Any help kindly appreciated.
         > Cheers,
         > Alessio.
        project,
        lameness
        <mailto:Geoserver-devel@lists.sourceforge.net>
    Via Carignoni 51
    55041 Camaiore (LU)
    fax: +39 0584983027
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
------------------------------------------------------- !DSPAM:4007,487732ef278366491211187!
Justin Deoliveira
The Open Planning Project
jdeolive@anonymised.com
Cool, that sounds better than the others, I will try that solution now.
Thanks Justin.
On Fri, Jul 11, 2008 at 6:58 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Hi Alessio,
  1. Change the generated class SpatialSubsetType “manually” so that its Envelope property is actually of the type geotools type envelope. I call this “instrumenting” the model.
-Justin
wcs:domainSubset
wcs:spatialSubset
</gml:Envelope>
gml:limits
gml:GridEnvelope
</gml:GridEnvelope>
</gml:limits>
</gml:Grid>
</wcs:domainSubset>
Alessio.
On Thu, Jul 10, 2008 at 4:18 PM, Alessio Fabiani <alessio.fabiani@anonymised.com mailto:[alessio.fabiani@anonymised.com](mailto:alessio.fabiani@anonymised.com)> wrote:
Hi Gabriel,
Gabriel
as a JTS
to some
gt-GML3 module
result of the
request is
at
at
erTest.java:86) at
Method) at
Source) at
at
at
  1. at
unner.java:460) at
unner.java:673) at
.java:386) at
failed for
property: Envelope
<http://www.opengis.net/wcs%7DSpatialSubsetType>
at
at
lker.java:208) at
:222) at
at
Source)
at
Source)
at
Source)
at
at
Source)
at
at
at
at
… 19 more
at
nding.java:271) at
java:143) at
… 35
more
'envelope’s type
at
  1. at
:94) at
) at
at
geotools converter
Alessio.
project,
lameness
mailto:[Geoserver-devel@anonymised.comt](mailto:Geoserver-devel@anonymised.comsts.sourceforge.net)
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Justin Deoliveira
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Hi Justin,
sorry to bother you again ... I tryied your solution, but I cannot
figure out how can be applied to this specific case. Let me better
describe the problem, the WCS 1.0.0 wcs:spatialSubset does not exactly
need just one gml:Envelope, but an unbounded set of gml:Envelopes ...
so the property of wcs:spatialSubset is an EList ... how this case can
be handled, and morover where is in GeoTools the source code of GML2
and GML3 EMF model? I can see just the bindings!
Thanks for any help,
                                 Alessio.
On Fri, Jul 11, 2008 at 7:01 PM, Alessio Fabiani
Thanks Justin.
wrote:
Hi Alessio,
solution:
-Justin
the following:
   <wcs:domainSubset>
       <wcs:spatialSubset>
           </gml:Envelope>
               <gml:limits>
                   <gml:GridEnvelope>
                   </gml:GridEnvelope>
               </gml:limits>
           </gml:Grid>
   </wcs:domainSubset>
represented below.
               Alessio.
   Hi Gabriel,
       Gabriel
        > Hi all,
       as a JTS
       to some
       gt-GML3 module
       result of the
following:
       request is
        > at
        > at
        >erTest.java:86) at
        > Method) at
       Source) at
        > at
        > at
        > at
        >38) at
        >unner.java:460) at
        >unner.java:673) at
        >.java:386) at
       failed for
       property: Envelope
        > at
        > at
        >lker.java:208) at
at
        >:222) at
        > at
        > Source)
        > at
        > Source)
        > at
        > Source)
        > at
        > at
        > Source)
        > at
        > at
Source)
        > at
        > at
        > ... 19 more
        > at
        >nding.java:271) at
        >java:143) at
       ... 35
        > more
       'envelope's type
        > at
        >46) at
        >:94) at
        >) at
        > at
       geotools converter
        > Cheers,
        > Alessio.
       project,
       lameness
   Via Carignoni 51
   55041 Camaiore (LU)
   fax: +39 0584983027
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Justin Deoliveira
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Justin, it's me again ... I found a workaround forcing the return type
of wcs:spatialSubset from EList to List and manually modifying both
the intrafece and the implementation, but I don't know if is the
correct way to do that, what do you think about?
On Mon, Jul 14, 2008 at 10:04 AM, Alessio Fabiani
Hi Justin,
                                Alessio.
Thanks Justin.
wrote:
Hi Alessio,
solution:
-Justin
the following:
   <wcs:domainSubset>
       <wcs:spatialSubset>
           </gml:Envelope>
               <gml:limits>
                   <gml:GridEnvelope>
                   </gml:GridEnvelope>
               </gml:limits>
           </gml:Grid>
   </wcs:domainSubset>
represented below.
               Alessio.
   Hi Gabriel,
   On Thu, Jul 10, 2008 at 4:06 PM, Gabriel Roldán <groldan@anonymised.com..
       Gabriel
        > Hi all,
       as a JTS
       to some
       gt-GML3 module
       result of the
following:
       request is
        > at
        > at
        >erTest.java:86) at
        > Method) at
       Source) at
        > at
        > at
        > at
        >38) at
        >unner.java:460) at
        >unner.java:673) at
        >.java:386) at
       failed for
       property: Envelope
        > at
        > at
        >lker.java:208) at
at
        >:222) at
        > at
        > Source)
        > at
        > Source)
        > at
        > Source)
        > at
        > at
        > Source)
        > at
        > at
Source)
        > at
        > at
        > ... 19 more
        > at
        >nding.java:271) at
        >java:143) at
       ... 35
        > more
       'envelope's type
        > at
        >46) at
        >:94) at
        >) at
        > at
       geotools converter
        > Cheers,
        > Alessio.
       project,
       lameness
   Via Carignoni 51
   55041 Camaiore (LU)
   fax: +39 0584983027
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Justin Deoliveira
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Hi Alessio,
So in this case the suggestion would then be to modify the list (via annotation) as to teh type of object inside of it. This could be done with something like this:
@model type="org.geotools.geometry.GeneralEnvelope"
EList getSpatialSubset()
So the deal is that there is actually no EMF model generated for GML. The reason being that geotools already has objects which represent many of the entities in gml like Feature, FeatureCollection, Envelope, etc...
So the strategy used for emf models which referenced GML (like WFS) was to just re-instrument the model in cases where GML elements and types are referenced.
Does that make sense?
We could go ahead and generate a EMF model for GML... It might save time in things like this. However for WFS it does not make sense since the reference was feature... and anything coming out of EMF would have to be adapted. For things like envelopes it might make more sense since its a much simpler data structure.
Hi Justin,
                                 Alessio.
Thanks Justin.
wrote:
Hi Alessio,
solution:
-Justin
the following:
   <wcs:domainSubset>
       <wcs:spatialSubset>
           </gml:Envelope>
               <gml:limits>
                   <gml:GridEnvelope>
                   </gml:GridEnvelope>
               </gml:limits>
           </gml:Grid>
   </wcs:domainSubset>
represented below.
               Alessio.
   Hi Gabriel,
       Gabriel
        > Hi all,
       as a JTS
       to some
       gt-GML3 module
       result of the
following:
       request is
        > at
        > at
        >erTest.java:86) at
        > Method) at
       Source) at
        > at
        > at
        > at
        >38) at
        >unner.java:460) at
        >unner.java:673) at
        >.java:386) at
       failed for
       property: Envelope
        > at
        > at
        >lker.java:208) at
at
        >:222) at
        > at
        > Source)
        > at
        > Source)
        > at
        > Source)
        > at
        > at
        > Source)
        > at
        > at
Source)
        > at
        > at
        > ... 19 more
        > at
        >nding.java:271) at
        >java:143) at
       ... 35
        > more
       'envelope's type
        > at
        >46) at
        >:94) at
        >) at
        > at
       geotools converter
        > Cheers,
        > Alessio.
       project,
       lameness
   Via Carignoni 51
   55041 Camaiore (LU)
   fax: +39 0584983027
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Justin Deoliveira
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Justin Deoliveira
Its definitely valid. To make it perminent however I think you might want to do the following:
* remove the @model annotation from the interface method
* remove all the @generated annoitation from the implementation method
That way the code generator will ignore (and not kill) any of the changed methods.
Did you try changing the "type" annotation as per my previous email?
Hi Justin,
                                Alessio.
Thanks Justin.
wrote:
Hi Alessio,
solution:
-Justin
the following:
   <wcs:domainSubset>
       <wcs:spatialSubset>
           </gml:Envelope>
               <gml:limits>
                   <gml:GridEnvelope>
                   </gml:GridEnvelope>
               </gml:limits>
           </gml:Grid>
   </wcs:domainSubset>
represented below.
               Alessio.
   Hi Gabriel,
       Gabriel
        > Hi all,
       as a JTS
       to some
       gt-GML3 module
       result of the
following:
       request is
        > at
        > at
        >erTest.java:86) at
        > Method) at
       Source) at
        > at
        > at
        > at
        >38) at
        >unner.java:460) at
        >unner.java:673) at
        >.java:386) at
       failed for
       property: Envelope
        > at
        > at
        >lker.java:208) at
at
        >:222) at
        > at
        > Source)
        > at
        > Source)
        > at
        > Source)
        > at
        > at
        > Source)
        > at
        > at
Source)
        > at
        > at
        > ... 19 more
        > at
        >nding.java:271) at
        >java:143) at
       ... 35
        > more
       'envelope's type
        > at
        >46) at
        >:94) at
        >) at
        > at
       geotools converter
        > Cheers,
        > Alessio.
       project,
       lameness
   Via Carignoni 51
   55041 Camaiore (LU)
   fax: +39 0584983027
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Justin Deoliveira
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Justin Deoliveira
Ok so,
I removed the @generaed annotation ane modified the @model one, but I
still need to slitghtly modify methods allowing them to handle
java.util.List instead of EList, otherwise I get the following error:
  ... 35 more
org.geotools.geometry.jts.ReferencedEnvelope cannot be cast to
org.eclipse.emf.ecore.InternalEObject
  at org.eclipse.emf.ecore.impl.EStructuralFeatureImpl$BasicFeatureMapEntry.createEntry(EStructuralFeatureImpl.java:2851)
  at org.eclipse.emf.ecore.util.FeatureMapUtil.createEntry(FeatureMapUtil.java:147)
  ... 38 more
On Tue, Jul 15, 2008 at 6:46 AM, Justin Deoliveira
do the following:
methods.
Hi Justin,
                               Alessio.
Thanks Justin.
wrote:
Hi Alessio,
third
solution:
call
-Justin
briefly
that
like
the following:
  <wcs:domainSubset>
      <wcs:spatialSubset>
          </gml:Envelope>
              <gml:limits>
                  <gml:GridEnvelope>
                  </gml:GridEnvelope>
              </gml:limits>
          </gml:Grid>
  </wcs:domainSubset>
to
instead.
into
attention
GMLConfiguration
GridType.
than
domainSubsetBinding
to
of the
follow ...
both
as
represented below.
              Alessio.
  Hi Gabriel,
  On Thu, Jul 10, 2008 at 4:06 PM, Gabriel Roldán <groldan@anonymised.com...
      Gabriel
       > Hi all,
      as a JTS
      to some
      gt-GML3 module
      result of the
1.0.0
following:
      request is
       > at
       > at
       >erTest.java:86) at
       > Method) at
      Source) at
       > at
       > at
       > at
       >38) at
       >unner.java:460) at
       >unner.java:673) at
       >.java:386) at
      failed for
      property: Envelope
       > at
       > at
       >lker.java:208) at
at
       >:222) at
       > at
       > Source)
       > at
       > Source)
       > at
       > Source)
       > at
       > at
       > Source)
       > at
Source)
       > at
Source)
Source)
       > at
Source)
       > at
       > ... 19 more
       > at
       >nding.java:271) at
       >java:143) at
      ... 35
       > more
      'envelope's type
       > at
       >46) at
       >:94) at
       >) at
       > at
      geotools converter
       > Cheers,
       > Alessio.
      project,
      lameness
  Via Carignoni 51
  55041 Camaiore (LU)
  fax: +39 0584983027
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Justin Deoliveira
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Justin Deoliveira
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Ahh... right, you are correct. It seems to assume that the objects inside of the list are eobjects as well. I ran into this same issue with wps. However I know I have done this before in wfs so there must be some way to do it... but this works just as well for now.
Ok so,
  ... 35 more
  ... 38 more
do the following:
methods.
Hi Justin,
                               Alessio.
Thanks Justin.
wrote:
Hi Alessio,
third
solution:
call
-Justin
briefly
that
like
the following:
  <wcs:domainSubset>
      <wcs:spatialSubset>
          </gml:Envelope>
              <gml:limits>
                  <gml:GridEnvelope>
                  </gml:GridEnvelope>
              </gml:limits>
          </gml:Grid>
  </wcs:domainSubset>
to
instead.
into
attention
GMLConfiguration
GridType.
than
domainSubsetBinding
to
of the
follow ...
both
as
represented below.
              Alessio.
  Hi Gabriel,
      Gabriel
       > Hi all,
      as a JTS
      to some
      gt-GML3 module
      result of the
1.0.0
following:
      request is
       > at
       > at
       >erTest.java:86) at
       > Method) at
      Source) at
       > at
       > at
       > at
       >38) at
       >unner.java:460) at
       >unner.java:673) at
       >.java:386) at
      failed for
      property: Envelope
       > at
       > at
       >lker.java:208) at
at
       >:222) at
       > at
       > Source)
       > at
       > Source)
       > at
       > Source)
       > at
       > at
       > Source)
       > at
Source)
       > at
Source)
Source)
       > at
Source)
       > at
       > ... 19 more
       > at
       >nding.java:271) at
       >java:143) at
      ... 35
       > more
      'envelope's type
       > at
       >46) at
       >:94) at
       >) at
       > at
      geotools converter
       > Cheers,
       > Alessio.
      project,
      lameness
  Via Carignoni 51
  55041 Camaiore (LU)
  fax: +39 0584983027
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Justin Deoliveira
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Justin Deoliveira
Justin Deoliveira
