[Geoserver-devel] emf models moved
I moved all the emf models that were in geoserver to geotools. The geotools deploy script should pick them up tonight (fingers crossed), for those who do not build geotools locally. For those that do, an update and rebuild of gt will be necessary.
I also recommend doing the following steps when you update geoserver:
* mvn clean eclipse:clean
* svn update
* mvn eclipse:eclipse -P <any profiles you use>
Caution: Having old copies of the models around in eclipse on the classpath (due to not updating community modules) will lead to weird class cast exceptions.
-Justin
Justin Deoliveira
The Open Planning Project
jdeolive@anonymised.com
