[Geoserver-devel] Enabling of services
Hi
I see that the wms and wfs services is enabled when the struts servlet
call its init() method.
This means that I have to access the front page of the server to be able
to use them wms and wfs services.
It this a design flaw? Or how we want it to be?
It means that there must be a manually lookup on the front-page if e.g.
the windows machine was restarted or the service was restarted before
the wms and wfs can be used.
The service seems to be started here:
public void init(ActionServlet as, ModuleConfig mc){} in
GeoServerPlugIn.java
Any thoughts?
Magne
Magne Skjeret wrote:
Hi
Nope, we are just abusing struts to get the modules to start up in a defined order. Nothing much happens with struts
until you hit the ui for the first time and the JSPCompiler kicks in.
No design flaw :wink: As for how we want it to be check out the 1.4.x branch which is spring based acutally
tracks the dependencies without abusing an XML file.
As said, this is not required. GeoServer runs, just turn it on.
Enjoy,
Jody
Hi
I am not sure if I followed you there.
Hi
Exactly, and that is why the wms and wfs service is not enabled, as it
is started when the jspcompiler or any other struts page is accessed
(the struts servlet started).
If you start your server and access this url before doing anything else:
http://127.0.0.1:8080/geoserver/wms?request=GetCapabilities&service=WMS
you will get a service not enabled exception.
If you then go here: http://nesstar.nsd.uib.no/geoserver/welcome.do
and then access the wms again you are fine.
Can't the services be started before strus has been started?
Magne
Enjoy,
Jody
This SF.net email is sponsored by: Splunk Inc. Do you grep through log
files
for problems? Stop! Download the new AJAX search engine that makes
searching your log files as easy as surfing the web. DOWNLOAD SPLUNK!
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=103432&bid=230486&dat=121642
Geoserver-devel mailing list
Hi Magne,
Just going to confirm this with GeoServer 1.3.0
Requesting: http://localhost:8080/geoserver/wms?request=GetCapabilities&service=WMS
We do need to wait for geoserver startup and wait for the application to say "started SocketListener....", we just finished testing this with a range of servlet containers. Pretty we tested against 1.3.0
In answer no, but hitting the web user interface != starting struts. The web.xml passes control off to struts
on startup, struts loads the modules into the application context. And then jetty starts listening ... you can see this as the
logs indicate the data is being loaded - that is struts kicking the data module into life.
Jody
Jody Garnett wrote:
Hi Magne,
Could it be a tomcat(jboss) issue?
I need to test a bit. Maybe I was to fast?
Requesting:
module into life.
It might be different in tomcat. Will have a look at it.
Magne
Jody
files
Jody Garnett wrote:
Hi Magne,
Could be.
Requesting:
module into life.
I just tried with tomcat 4, had no problems.
Magne
Jody
files
This SF.net email is sponsored by: Splunk Inc. Do you grep through log files
Chris Holmes
The Open Planning Project
thoughts at: http://cholmes.wordpress.com
Jody Garnett wrote:
Hi Magne,
Perhaps? We just did performance tests with Jetty, Tomcat, Resin, and JBoss. Can't say we never looked at the user interface in all cases...
No worries, now you know what to look for in the logs.
module into life.
Best of luck and report back, for your own interest JBoss was much faster then the alternatives (including resin).
Jody
I restart geoserver often without going to a struts page. You just have to make sure it is loaded fully.
Brent Owens
(The Open Planning Project)
Hi
Any thoughts?
Magne
