Correct, will do, thanks.
2015-03-24 15:51 GMT+01:00 Jody Garnett <jody.garnett@anonymised.com>:
Remember to add to the docs
Jody Garnett
On 24 March 2015 at 06:20, Mauro Bartolomeoli <mauro.bartolomeoli@anonymised.com> wrote:
this is first implementation attempt: https://github.com/mbarto/geoserver/commit/8c3f908008fa5482b754871c3ef17b64e4e6c533
What do you think?
Mauro
Dive into the World of Parallel Programming The Go Parallel Website, sponsored
by Intel and developed in partnership with Slashdot Media, is your hub for all
things parallel software development, from weekly thought leadership blogs to
news, videos, case studies, tutorials and more. Take a look and join the
conversation now. http://goparallel.sourceforge.net/
Geoserver-devel mailing list
2015-03-24 8:28 GMT+01:00 Andrea Aime <andrea.aime@anonymised.com>:
Dott. Mauro Bartolomeoli
@mauro_bart
Senior Software Engineer
Via Poggio alle Viti 1187
On Mon, Mar 23, 2015 at 6:00 PM, Mauro Bartolomeoli <mauro.bartolomeoli@anonymised.com> wrote:
I would like to add the possibility to access, from GetFeatureInfo ftl templates,
environment properties (those accessible through System.getProperties() ) using a specific variable name (system, for example).
We did a similar thing some time ago for request parameters, using the variable request.
With this improvement we will be able to write this kind of stuff in the template:
and resolve WEB_SITE_URL with a setting in Tomcat startup script, such as:
-DWEB_SITE_URL=“http://mysite.com/”
My purpose is to have templates that can be installed in different environments and where some details are different and be able to specify those details from a starting script.
I’d suggest to use GoeServerExtensions.getProperty(String) to lookup variables, as it can lookup from web.xml, system and enviroment variable,
the mechanism is already familar to GeoServer users (data dir, logging dir, and so on, there are some ~50 references to those getProperty(*) methods spread in the code base),
and having a choice of multiple ways to set the values can be handy.
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
@mauro_bart
