On Mon, Mar 23, 2015 at 10:27 PM, Jody Garnett <jody.garnett@anonymised.com>
wrote:
Related to Mauro's request for system property access when writing ftp
templates, I would like to set up alternatives to the "data directory" for
path definition.
I am not sure if system properties are the best way to manage these kind
of environment or instance level configuration settings. For data directory
we have a more general approach:
1) web.xml (web app specific)
2) system properties (JVM or AppServer specific)
3) environmental variables (system specific)
For Mauro's WEB_SITE_URL setting I could see each of these options making
sense.
Hum... yeah, those are the 3 ways a setting can be setup in GeoServer, and
GoeServerExtensions.getProperty(String) will do the lookup accordingly.
Might make sense to use that in Mauro's proposal.
Currently we use data directory for two things: the location of the xml
configuration files and as a base URL when working with file formats such
as shapefile and geotiff. We have a related of base URL when working with
styles and icons.
Customers have long run into the limitation of this approach - setting up
an external folder to store large vector and raster datasets and then using
absolute file references.
An idea I would like to float (and can write up a proposal if we like it)
is to allow an administrator to define additional data locations and assign
them a variable name we can use in a data URL.
We actually had that for a long time with the multiple resource loaders (we
just lacked the support for a variable based one) but... didn'nt you kill
that support with the resource store work?
Examples:
* ${shared}/annual/zones.shp - example of a customer shared data location
defined by admin
Where would this variable be set? 1), 2), 3) as above, or somewhere in the
GeoServer global settings?
If they can be changed while GeoServer is running we have to consider it at
the ResourcePool level, all stores using them
must be disposed of.
* ${workspace}/data - the default location for data upload, the builtin
variable workspace allows for stable URLs when workspace renamed
So if you rename the workspace there is going to be some procedure that
moves all the files in that folder to the new one?
Or are you going to invalidate all stores pointing to that variable on
rename?
Plus, it would seem to me that ${workspace} needs to be relative to
something else too, like, I would probably code it up
as ${shared}/${workspace}.
I would also point out that for uploads, we already have a pluggable API in
REST config that can be used to decide where to put the files,
used for that very purpose:
https://github.com/geoserver/geoserver/wiki/GSIP%20114%20-%20PathMapper%20extension%20point%20to%20control%20REST%20file%20upload%20locations
When using the file browser in addition to data directory, home and file
system the locations defined by the administrator can also be listed.
Hum.. .yeah, I guess in theory the browser should be smart enough to
replace the variable when there is a path bit that
uses them?
Or did you want to make it simpler, and just provide the variables as
roots? Works best if a path can contain a single variable I guess...
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
