[Geoserver-devel] EPSG:102113
My WMS GetCapabilities lists 3,911 available EPSG codes, but 102113 isn’t one of them.
Apparently the US Geological Survey’s new National Map viewer prefers this.
Here’s their info:
Many Web Map Services (WMS) are setup to only support Geographic WGS84 or EPSG:4326. Make sure to enable EPSG:102113.
Your service must support Projected WGS84 Web Mercator or EPSG:102113.
I do have a “EPSG:WGS84(DD)” - is this the same thing?
Freeman, Aleda (EEA) wrote:
My WMS GetCapabilities lists 3,911 available EPSG codes, but 102113 isn't one of them.
Apparently the US Geological Survey's new National Map viewer prefers this.
Here's their info:
I do have a "EPSG:WGS84(DD)" - is this the same thing?
No, it's not. That code is not even an official EPSG one, as far as I can tell it's ESRI specific:
http://www.spatialreference.org/ref/sr-org/45/
I just looked in the latest and greatest of EPSG databases (version 7.4)
and 102113 is not among them.
It seems a shame that a public service forces people to use
a vendor specific code.
Anyways, I think you can add it into the user defined projections
in GeoServer
I did add it into the user defined projections in GeoServer and it works
great.
It doesn't work in The National Map Beta viewer, but that's not
GeoServer's fault,
because my GetMap with EPSG:102113 and bounding box with 102113 coords
works just fine!
-----Original Message-----
Sent: Thursday, December 10, 2009 4:59 PM
To: Freeman, Aleda (EEA)
Cc: Geoserver-devel
Subject: Re: [Geoserver-devel] EPSG:102113
isn't one of them.
this.
Here's their info:
It seems a shame that a public service forces people to use a vendor
specific code.
Anyways, I think you can add it into the user defined projections in
great.
GeoServer's fault,
works just fine!
Well, hope that you/them will sort out what's wrong.
But seriously, couldn't they use the official EPSG code for the
Google projection instead?
EPSG:3857
Andrea Aime
OpenGeo - http://opengeo.org
I agree, I don't see why they couldn't have picked one of the already
available ones....
I just wanted to say that I'm impressed at how easy it was to add
another projection!
Another plus for GeoServer.
available ones....
another projection! Another plus for GeoServer.
Ah, the sound of a happy user! :slight_smile:
Andrea Aime
