Is it possible to limit the available SRS returned from GeoServer WMS?
GetCapabilities returns an enormeous list (3900+)…
I need help…
Thanks
Francesco @ MacOSX “TiGeR 10.4.9”
I need help…
Thanks
Hi Fransesco,
(this is probably a more suitable question for the users list).
The answer is no. I know its a pain to process the capabilities document, but there is no good way to limit it at this time. It is something we will be taking into account while redoing the core configuration work.
-Justin
Francesco Izzi wrote:
Is it possible to limit the available SRS returned from *GeoServer* WMS?
GetCapabilities returns an enormeous list (3900+)....I need help...
Thanks
Francesco @ MacOSX "TiGeR 10.4.9" !DSPAM:4007,47ea393f73492090977483!------------------------------------------------------------------------
Check out the new SourceForge.net Marketplace.
It's the best place to buy or sell services for
just about anything Open Source.
http://ad.doubleclick.net/clk;164216239;13503038;w?http://sf.net/marketplace!DSPAM:4007,47ea393f73492090977483!
Geoserver-devel mailing list
https://lists.sourceforge.net/lists/listinfo/geoserver-devel!DSPAM:4007,47ea393f73492090977483!
Justin Deoliveira
The Open Planning Project
jdeolive@anonymised.com
(please keep questions on the public list).
As a workaround, one thing you can do is:
1. Download the wms capabilities document
2. Manually remove all the SRS's you do not want
3. Publish the the capabilities document (via web server) on the same server as geoserver
The problem with this is of course the capabilities document will not reflect any changes you make to layers in GeoServer.
-Justin
ArchGis is very very slow to retrive responce from geoserver ....
Why?
uDig is faster...2008/3/26, Justin Deoliveira <jdeolive@anonymised.com <mailto:jdeolive@anonymised.com>>:
Hi Fransesco,
configuration work.-Justin
> Hi,
*GeoServer* WMS?
> I need help...
> Thanks
> --> Francesco @ MacOSX "TiGeR 10.4.9"
<mailto:Geoserver-devel@lists.sourceforge.net>
Justin Deoliveira
jdeolive@anonymised.com <mailto:jdeolive@anonymised.com>--
Francesco @ MacOSX "TiGeR 10.4.9" !DSPAM:4007,47ea680f144671637810514!
Justin Deoliveira
Francesco, all
we decided to take action on this one for good.
Add yourself as a watcher of <http://jira.codehaus.org/browse/GEOS-1830> to be
notified when its done.
regards,
Gabriel
server as geoserverThe problem with this is of course the capabilities document will not
reflect any changes you make to layers in GeoServer.-Justin
> Why?
> uDig is faster...
> Hi Fransesco,
> configuration work.
> -Justin
> > Hi,
> *GeoServer* WMS?
> > I need help...
> > Thanks
>ace
> > _______________________________________________
> Justin Deoliveira
