[Geoserver-devel] epsg
Hello,
i am not sure, if it's the correct list for my question.
Sorry if not.
I think Geoserver works fine on my computer.
If i try to load my data in the Cadcorp SIS Map Browser all steps
work, but i see nothing. If i send the getFeature-request from my
browser to the Geoserver, i get the answer as gml. I noticed, that
the epsg code is referenced to http://www.opengis.net/gml/srs/epsg.xml#4326.
But this document doesn't exist.
Is this an error in my configuration?
Thanks in advance.
Heiko
Sorry if not.
This list is fine, the user list hasn't quite taken off.
No, that's a URI, not a URL - which is to say it's a reference to an
identifier, not a location on the internet. The location should be
specified with an schemaLocation in the header - but for the epsg stuff
this is not necessary as they should be well known, browsers should be
able to read them. I think the client should be able to read both
srs="http://www.opengis.net/gml/srs/epsg.xml#4326" style and the
srs="EPSG:4326" style. I have been meaningto make an option in geoserver
to support both - we did the first way since that was what was in the
spec.
I'm not positive, but a few months ago I _think_ we tested with cadcorp's
client, and they made a bug fix for that very problem. It might have been
another company, but you may try to get in touch with them to see if they
have a patch, and it may fix your problem.
Chris
