Hello, I am trying to start geoserver on Fedora Core 3 but the following error appears: [root@anonymised.com bin]# pwd I didn’t start the jetty (and don’t know if it is necessary) The error is in the last line of the startup.sh script and it try to load a jar file that doesn’t have the correspondent directory: org.mortbay.jetty Please tell me something about my error. I need to star the server as soon as possible. Best regards =-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- A pior das democracias ainda é melhor do que a melhor das ditaduras |
Sound's like you're missing a the org.mortbay.jetty.jar. Do you have a
lib directory? I think I've heard reports that it maybe didn't get in
one of the releases? If there's not a geoserver/lib directory, or not
a geoserver/lib/jetty (or jetty/org.mortbay.jetty.jar) then download a
previous version of GeoServer, and copy over the full lib directory.
If you need quicker help I just jumped on
irc://irc.freenode.net#geotools, and will do what I can to get you
started up quickly.
best regards,
Chris
Quoting Ezequias Rodrigues da Rocha <ezequias@anonymised.com>:
Hello,
error
appears:[root@anonymised.com bin]# pwd
/geoserver/bin
[root@anonymised.com bin]# ./startup.sh
java.lang.ClassNotFoundException: org.mortbay.jetty.Server
at java.net.URLClassLoader$1.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at org.mortbay.start.Main.invokeMain(Main.java:145)
at org.mortbay.start.Main.start(Main.java:482)
at org.mortbay.start.Main.main(Main.java:90)
[root@anonymised.com bin]#I didn't start the jetty (and don't know if it is necessary)
load a
jar file that doesn't have the correspondent directory:
org.mortbay.jettyPlease tell me something about my error. I need to star the server as
soon
as possible.Best regards
Atenciosamente (Sincerely)
* www.recife.pe.gov.br
The worst of democracies is still better than the better of
dictatorships
MSN Messenger: ezequias@anonymised.com
This mail sent through IMP: https://webmail.limegroup.com/
