HI every body, I’ve got this error giving the
mvn -Dmaven.test.skip=true -Dawt.headless=true clean install assembly:assembly
command
[INFO] Installing /Users/superandrew/Documents/Tesi/geoserver/net.opengis.wfs/target/net.opengis.wfs-1.7.0-SNAPSHOT-tests.jar to /Users/superandrew/.m2/repository/org/geoserver/net.opengis.wfs/1.7.0-SNAPSHOT/net.opengis.wfs-1.7.0-SNAPSHOT-tests.jar
[INFO] ----------------------------------------------------------------------------
[INFO] Building Web Feature Service Module
[ERROR] BUILD ERROR
[INFO] The plugin ‘org.geotools.maven:gt2-xmlcodegen’ does not exist or no valid version could be found
[INFO] Total time: 19 seconds
[INFO] Finished at: Wed Jan 16 22:46:02 CET 2008
[INFO] Final Memory: 27M/63M
Any idea?
Thanks
Superandrew
http://www.superandrew.it
Thanks for reporting this. You could get around this by checking out
geotools and building it from source. But i just made a change to a
couple of the pom.xml files so that this should not happen any more.
Can you do an svn update and try again. I assume you are working from svn?
Andrea Maschio wrote:
HI every body, I've got this error giving the
assembly:assembly
command
[INFO] Installing
to
[INFO]
[INFO]
[INFO]
[ERROR] BUILD ERROR
[INFO]
[INFO] The plugin 'org.geotools.maven:gt2-xmlcodegen' does not exist or
[INFO]
[INFO]
[INFO]
Any idea?
Thanks
Superandrew
http://www.superandrew.it/>
!DSPAM:4007,478e7da3206415409313003!
Defy all challenges. Microsoft(R) Visual Studio 2008.
Geoserver-devel mailing list
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
Justin, after update all was fine.
Thanks
assembly:assembly
command
[INFO] Installing
to
[INFO]
[INFO]
[INFO]
[ERROR] BUILD ERROR
[INFO]
[INFO]
[INFO]
[INFO]
Any idea?
Thanks
Superandrew
Justin Deoliveira
